Fan to kick on at set temperature?
PostPosted: Wed Oct 15, 2014 1:04 pm
I want to be able to turn a fan on in my canopy at a set temperature and then have it turn off either when the water temp drops or at a set time; how do I do that?
Say I want the fan to kick on when the water hits 82F and then kick off if it hits 81F or at a set time (the end of the mh light cycle).
    InternalMemory.OverheatTemp_write( 845 );
    ReefAngel.StandardHeater( Port1,795,800 );
    ReefAngel.StandardHeater( Port2,794,800 );
    ReefAngel.StandardLights( Port3,24,0,15,0 );   ////scrubber lights 12am-3pm  15hrs on 9off
    ReefAngel.StandardLights( Port4,16,0,24,0 );  ////Canopy Fan 4pm to 12am
    ReefAngel.StandardLights( Port5,16,0,23,0 ); ////Metal Halide 4pm to 11pm
    ReefAngel.DosingPumpRepeat( Port6,0,660,10 ); /////mag 720min = 11hrs  15ml day
    ReefAngel.DosingPumpRepeat( Port7,0,360,26 );  /////alk 360min = 6hrs  78ml day
    ReefAngel.DosingPumpRepeat( Port8,0,300,21 );  ////cal 300min = 5hrs   78.75ml day 3cups per gal
    ReefAngel.DCPump.SetMode( LongPulse,60,10 );
    if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()==8 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,85,20);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,75,40 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,85,4 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ReefCrest,56,20 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( LongPulse,80,5 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( LongPulse,75,14 );
else if (hour()==23 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,90,5);
   ReefAngel.AddWifi();
    ReefAngel.Portal( "davidinga" );
    int x,y;
    // pH Expansion
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
PostPosted: Wed Oct 15, 2014 1:54 pm
ReefAngel.StandardFan(PortX,81,82);
PostPosted: Wed Oct 15, 2014 2:02 pm
Didn't know their was a fan code. Lol
So...
ReefAngel.StandardFan(Port4,81,82);
Kicks the fans on at 82f and off at 81f?
Am I able to code in a window of time where that applies too?
PostPosted: Wed Oct 15, 2014 3:14 pm
Yeah we just need to wrap it in an if statement with the times you want. Are you using internal memory for your MH?
PostPosted: Wed Oct 15, 2014 6:18 pm
How about this instead of a time window? (this is easier to code/read)
if (ReefAngel.Relay.Status(Port5))
  ReefAngel.StandardFan(Port4,81,82))
  ReefAngel.Relay.Off(Port4);
This nice thing about that is that if you change your MH schedule or change it to use memory, it won't matter here.
If your halides are on then it will look to use the fan if necessary. Otherwise fan is off.
PostPosted: Wed Oct 15, 2014 9:33 pm
lnevo wrote:How about this instead of a time window? (this is easier to code/read)
Sweet.
So where would I put that code and what do I do with the existing code I have for the fan?
PostPosted: Thu Oct 16, 2014 3:25 am
Comment it out. Put this in the custom section inside loop
PostPosted: Thu Oct 16, 2014 12:57 pm
Does my code look correct?
    if (hour()<8)
    int x,y;
    // pH Expansion
What about the line:
Do I leave that in there like it is or what???
PostPosted: Thu Oct 16, 2014 3:44 pm
You can leave it, but I would comment it out or remove it to avoid confusion.
PostPosted: Sat Oct 18, 2014 1:20 pm
The code is not working.
    if (hour()<8)
    int x,y;
    // pH Expansion
I click "Verify" and it says:
sketch_Oct_18_2014_Metal_Halides.cpp: In function 'void loop()':
sketch_Oct_18_2014_Metal_Halides:114: error: expected `;' before ')' token
So...I changed the error to this:
Which passed Verify. So I uploaded that to the RA+ and my fan port continues to run like before (my water temp on the probe is 80.6F btw).
What am I doing wrong here?
Next
Return to How do I code ...
