Fan to kick on at set temperature?
Posted: Wed Oct 15, 2014 1:04 pm
I want to be able to turn a fan on in my canopy at a set temperature and then have it turn off either when the water temp drops or at a set time; how do I do that?
Say I want the fan to kick on when the water hits 82F and then kick off if it hits 81F or at a set time (the end of the mh light cycle).
InternalMemory.OverheatTemp_write( 845 );
ReefAngel.StandardHeater( Port1,795,800 );
ReefAngel.StandardHeater( Port2,794,800 );
ReefAngel.StandardLights( Port3,24,0,15,0 ); ////scrubber lights 12am-3pm 15hrs on 9off
ReefAngel.StandardLights( Port4,16,0,24,0 ); ////Canopy Fan 4pm to 12am
ReefAngel.StandardLights( Port5,16,0,23,0 ); ////Metal Halide 4pm to 11pm
ReefAngel.DosingPumpRepeat( Port6,0,660,10 ); /////mag 720min = 11hrs 15ml day
ReefAngel.DosingPumpRepeat( Port7,0,360,26 ); /////alk 360min = 6hrs 78ml day
ReefAngel.DosingPumpRepeat( Port8,0,300,21 ); ////cal 300min = 5hrs 78.75ml day 3cups per gal
ReefAngel.DCPump.SetMode( LongPulse,60,10 );
if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()==8 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,85,20);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,75,40 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,85,4 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ReefCrest,56,20 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( LongPulse,80,5 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( LongPulse,75,14 );
else if (hour()==23 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,90,5);
ReefAngel.AddWifi();
ReefAngel.Portal( "davidinga" );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
