control external relay with PWM expansion.
sesame
Post by sesame »
I just DIY another automatic zeovit reactor with Pump. as zeo system request, pump should be running as 3hours on/off schedule. unfortunately i dont have spare relay port.
since i got a PWM expansion with 4 ports free. is it possible to trigger a external relay by dimming expansion port.
i'd rather to use dosing pump library. It will be much easier to adjust interval timing.
i suppose code should be like this.
ReefAngel.DosingPumpRepeat1(ReefAngel.PWM.SetChannel(2,100))
or
ReefAngel.DosingPumpRepeat1(Pinmode(PWMports[2],output));
Re: control external relay with PWM expansion.
It won't work that way.
You can certainly use the dimming module to trigger a relay.
Be careful not to oversize the relay.
The max current per channel is 40mA. So, look for a relay that has a coil that will draw less than that.
You can use something like this though:
ReefAngel.DosingPumpRepeat1(Box1_Port1);
ReefAngel.PWM.SetChannel(2,ReefAngel.Relay.Status(Box1_Port1)*100);
This code basically uses relay expansion box as virtual relay, even if you don't have it.
So, it will trigger the port 1 just using the dosing pump function and you can change the settings with phone app or portal.
Then, your dimming channel will follow the status of that port :)
sesame
Post by sesame »
thanks Robert
