I am a copy/paste programmer and recently purchased litermeter dosing pumps for a continuous water change and plan to run them every 9 min. I would like to know how to program my RA+ so that way I can calibrate the pumps and have it auto set the run time. I would like to change roughly 1 gal/day in my 29 gal biocube.#include <ReefAngel_Features.h>
ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port4Bit;
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.DayLights( Port6 );
ReefAngel.DosingPumpRepeat1( Box1_Port1 );
ReefAngel.DosingPumpRepeat2( Box1_Port2 );
ReefAngel.DayLights( Box1_Port3 );
ReefAngel.DayLights( Box1_Port4 );
ReefAngel.MoonLights( Box1_Port7 );
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.PWM.Channel4PWMParabola();
ReefAngel.PWM.Channel5PWMParabola();
ReefAngel.Portal( "Rodasphoto" );
Calibration for dosing pumps
- Rodasphoto
- Contact:
Re: Calibration for dosing pumps
My understanding of the litermeter system is that you calibrate it and set it up using it own control system to do the water changes and dose the correct amount per each pump.
Someone in my reef club just tested one a did a review of it in terms of water changes.
Among the few cons that he had with it was that it was a stand along system and that it could not be controlled by his Apex. The RA and Apex are very similar in what they can and can not control so I'm thinking it can not be controlled by a third party controller.
Take a look at his review of the LM3.
http://www.reef2reef.com/forums/do-your ... ost2008059
- Rodasphoto
- Contact:
I got just the pumps. There is no controller as I knew the RA could be programmed to run it.
http://spectrapure.com/AQUARIUM/LITER-M ... sing-Pumps
Sent from my XT1060 using Tapatalk
You can look at my code for calibrating my dosing pumps. It doesn't work that well for measuring my water changes. I haven't figure out quite why...
- Rodasphoto
- Contact:
Your code is what gave me the idea. I would love to implement a lot of what you have in your code to my tank. The only thing is when I copied and pasted your code into a text editor it was like 30 pages long. I am still to much of a newb to make heads or tails right of it now. I need to look at it again and try and pick out the relevant parts.lnevo wrote:You can look at my code for calibrating my dosing pumps. It doesn't work that well for measuring my water changes. I haven't figure out quite why...
