I am using the following code for my reefangel.
I have managed to get my dc wave pumps working the way I like it.
the big problem is that the pumps does not switch off when I go into feeding mode.
Please let me know what code I need to add?
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
ReefAngel.StandardLights( Port1,6,45,19,0 );
ReefAngel.StandardLights( Port2,11,45,17,30 );
ReefAngel.StandardHeater( Port3,240,255 );
ReefAngel.StandardHeater( Port4,240,255 );
ReefAngel.StandardFan( Port5,260,265 );
ReefAngel.CO2Control( Port7,650,660 );
ReefAngel.Relay.DelayedOn( Port8,3 );
static unsigned long atoTimer;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) atoTimer=now();
if (now()-atoTimer < 120) {
ReefAngel.Relay.Off(Port6);
} else {
ReefAngel.SingleATO( true,Port6,60,0 );
if (hour()>=7 && hour()<11)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,80,1,true) ); // Ramp from 0% to 80% with 1 min duration in sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,80,1,false) );
if (hour()>=11 && hour()<20)
ReefAngel.PWM.SetDaylight( ElseMode(80,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ElseMode(80,20,false) );
else if (hour()>=20 && hour()<23)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,4000,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
ReefAngel.PWM.SetActinic( NutrientTransportMode(40,80,4000,false) );
else if (hour()>=23 && hour()<7)
ReefAngel.PWM.SetDaylight( ElseMode(40,15,true) ); // ReefCrest at 45% +/- 15% on sync mode
ReefAngel.PWM.SetActinic( ElseMode(40,15,false) );
if(ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Off(Port8);
ReefAngel.Relay.On(Port8);
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
