static bool feedStart; // Flag to see when feed mode has started
static unsigned long feedTimer; // timer to track when to trigger the feeder
//static int powerUpdelay = 10000;
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit ;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
    // Ports that are start off
    ReefAngel.Relay.Off( Port1 );
    // Set Return Pump to 90%
    ReefAngel.PWM.SetDaylight(90);
    //delay(powerUpdelay);
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    //ReefAngel.Relay.DelayedOn( Port5,10 );
    //ReefAngel.Relay.DelayedOn( Port6,20 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.CustomLabels[0]="ATO";
    ReefAngel.CustomLabels[2]="Fuge";
    ReefAngel.CustomLabels[3]="GFO";
    ReefAngel.CustomLabels[4]="Jabeo";
    ReefAngel.CustomLabels[5]="MP10";
    ReefAngel.CustomLabels[6]="Heater";
    ReefAngel.CustomLabels[7]="Return";
    ReefAngel.SingleATO( true,Port1,60,0 );
    ReefAngel.StandardHeater( Port7,708,810 );
if (ReefAngel.DisplayedMenu!=FEEDING_MODE) feedStart=false; // Reset the flag...
if (ReefAngel.DisplayedMenu==FEEDING_MODE && feedStart==false) {
  feedStart=true; // So we don't start the timer more than once per feeding mode.
  feedTimer=now(); // We're going to use this time to see if 2 minutes is up before we trigger the feeder.
if ( feedStart==false) // 2 min later activate auto feeder
  ReefAngel.PWM.SetDaylight(50);
    ReefAngel.Portal( "g6gang" );
So today I went to go into feed mode (using local web page) and nothing happened. No pumps shut off. So I am trying to figure out how things got out of sync and how to correct/ensure this does not happen again. I am going away for week and wifey will be in control of 'feeding' - concerned she will not turn everything back on and just want her to click the feed button.
On the Android app, the Water change mode flag current says 'off' as well as 'feeing mode'
I have not tried to reboot RA yet.
