Things I am needing help with
Re: Things I am needing help with
I'm not sure the timezone offset thing is wierd because of the way the arduino works. If you change the actinic offset and reset the controller you should see the daylight time shift to accommodate the changed actinic offset.
I think i can add a patch so if the offset changes, the time change can reflect immediately.
No patch necessary. It updated over night, and worked as expected.
Will try the revised code to reverse ATO float later today. Thanks much for all you help.
I think all I am wanting to do now is add the automatic temp changes according to month. This chunk of code code is borrowed from hedricksms. I will tinker with it some more and see if I can figure it out.
void SeasonalTemps ()
ReefAngel.CustomVar[0]=month();
static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
{770,774},//January (winter)
{774,778},//February (winter)
{775,779},//March (early spring)
{779,783},//April (spring)
{785,789},//May (spring)
{792,796},//June (early summer)
{799,803},//July (summer)
{806,810},//August (summer)
{796,801},//September (early fall)
{787,791},//October (fall)
{780,784},//November (fall)
{775,779} };//December (early winter)
static int coolArray[][2] = { {794,799},// default in case of error in month=0 (June)
{772,776},//January (winter)
{776,780},//February (winter)
{777,781},//March (early spring)
{781,785},//April (spring)
{787,791},//May (spring)
{794,798},//June (early summer)
{801,805},//July (summer)
{808,812},//August (summer)
{798,803},//September (early fall)
{789,793},//October (fall)
{782,786},//November (fall)
{777,781} };//December (early winter)
ReefAngel.StandardHeater( Heater,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.StandardFan(Cooling,coolArray[month()][0],coolArray[month()][1]);
}//end seasonalTemps
You could post the error you're getting when you compile that will help immensely.
I'll still do the patch at some point because it annoys me
Trying with this code.
Getting the error:
L1.cpp: In function 'void SeasonalTemps()':
L1:325: error: 'Heater' was not declared in this scope
L1:326: error: 'Cooling' was not declared in this scope
Getting the error:
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
SunLocation sl;
int avgph[10];
unsigned long totalavgph=0;
byte avgindex=0;
byte x;
byte y = 2;
char text[7];
// *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
int TempColor; // Color for drawing temperature
boolean FanOn = ReefAngel.Relay.Status(Port5); // Get the status of the fan relay
boolean HeatOn = ReefAngel.Relay.Status(Port6); // Get the status of the heater relay
if (HeatOn)
TempColor = COLOR_NAVY; // Blue text, too cold, heater is on
if (FanOn)
TempColor = COLOR_RED; // Red text, too warm, fan is on
if (!HeatOn && !FanOn)
TempColor = COLOR_GREEN; // Green text, no fan or heater on
int pHColor; // Color for drawing pH
boolean LowpH = (ReefAngel.Params.PH < 780) ; // Check for Low pH Value
boolean HighpH = (ReefAngel.Params.PH > 850); // Check for High pH Value
if (LowpH)
pHColor = COLOR_NAVY; // Blue text, Low pH value
if (HighpH)
pHColor = COLOR_RED; // Red text, High pH value
if (!LowpH && !HighpH)
pHColor = COLOR_GREEN; // Green text, pH acceptable
ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8); // Put a banner at the top
ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12); // Draw a cyan line under the banner
x = 6;
y += MENU_START_ROW*1.4; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp pH");
ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
x = 2;
y += MENU_START_ROW*1.6;
ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text); // Draw the temperature, white numbers on a colored background
ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
x = 2;
y = MENU_START_ROW*2.6;
ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text); // Put pH on the screen
x += 6;
y += MENU_START_ROW*3.3;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8); // Draw the Sump Float switch status
ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
x += 6;
y += MENU_START_ROW*2.0;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8); // Draw the Skimmer Cup Float switch status
byte TempRelay = ReefAngel.Relay.RelayData; // Code for drawing the relay box
ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port7 );
sl.Init(35.5022, 97.7492); // In decimal numbers (i.e. -18.285833, 147.699722)
sl.SetOffset(7,0,7,0); // rise_hour, rise_seconds, set_hour, set_seconds
randomSeed(now()%SECS_PER_DAY);
//Custom Variable [0] = Month/Season
ReefAngel.CustomLabels[0]="Return";
ReefAngel.CustomLabels[1]="Daylights";
ReefAngel.CustomLabels[2]="Actinics";
ReefAngel.CustomLabels[3]="Fuge Light";
ReefAngel.CustomLabels[4]="Sump Fan";
ReefAngel.CustomLabels[5]="Heater";
ReefAngel.CustomLabels[6]="Skimmer";
ReefAngel.CustomLabels[7]="ATO";
// seasonal temperatures
SeasonalTemps();
ReefAngel.DayLights( Port2 ); // ATI DayLights (White+Purple) On 1 hr after sunrise, off 1 hr before sunset.
ReefAngel.ActinicLights( Port3 ); // ATI Actinic+ Lights (Blues). On at sunrise, off at sunset.
ReefAngel.MoonLights( Port4 ); // Refugium light. On 1 hr before sunset, off 1 hr after sunrise.
if (hour()>=9 && hour()<11)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,55,10,true) ); // Long pulse at 55% with 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,55,10,false) ); // Long pulse at 55% with 10s pulse on Anti-sync mode
else if (hour()>=11 && hour()<12)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,60,5,true) ); // Long pulse at 60% with 5s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,60,5,false) ); // Long pulse at 60% with 5s pulse on Anti-sync mode
else if (hour()>=12 && hour()<13)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,65,2,true) ); // Long pulse at 65% with 2s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,65,2,false) ); // Long pulse at 65% with 2s pulse on Anti-sync mode
else if (hour()>=13 && hour()<14)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,69,680,true) ); // Short pulse at 71% with 680ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,69,680,false) ); // Short pulse at 71% with 680ms pulse on Anti-sync mode
else if (hour()>=14 && hour()<15)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,73,680,true) ); // Short pulse at 78% with 680ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,73,680,false) ); // Short pulse at 78% with 680ms pulse on Anti-sync mode
else if (hour()>=15 && hour()<16)
ReefAngel.PWM.SetDaylight( ShortPulseMode(0,78,690,true) ); // Short pulse at 87% with 680ms pulse on sync mode
ReefAngel.PWM.SetActinic( ShortPulseMode(0,78,690,false) ); // Short pulse at 87% with 680ms pulse on Anti-sync mode
else if (hour()>=16 && hour()<17)
else if (hour()>=17 && hour()<18)
else if (hour()>=18 && hour()<19)
else if (hour()>=19 && hour()<20)
else if (hour()>=20 && hour()<21)
ReefAngel.PWM.SetDaylight( ReefCrestMode(40,10,true) ); // reefcrest at 40% +/- 10% on sync mode (night Mode)
ReefAngel.PWM.SetActinic( ReefCrestMode(40,10,true) ); // reefcrest at 40% +/- 10% on sync mode (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
if(ReefAngel.LowATO.IsActive()) // Float switch in Skimmer Cup
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.Off(Port7); // Turn off Skimmer when Cup full.
if(ReefAngel.HighATO.IsActive()) // Float switch in Sump
ReefAngel.Relay.On(Port8); // Run ATO pump.
ReefAngel.Relay.Off(Port8); // Sump level acceptable.
ReefAngel.SingleATO(false,Port8,180,0); // Sump switch. If ATO runs for 180 seconds, then shut off and send alert.
// handle updating sunrise and sunset values
sl.CheckAndUpdate();
ReefAngel.Portal( "DmnYnkee" );
static int coolArray[][2] = { {794,797},// default in case of error in month=0 (June)
{772,775},//January (winter)
{776,779},//February (winter)
{777,780},//March (early spring)
{781,784},//April (spring)
{787,790},//May (spring)
{794,797},//June (early summer)
{801,804},//July (summer)
{808,811},//August (summer)
{798,802},//September (early fall)
{789,792},//October (fall)
{782,785},//November (fall)
{777,780} };//December (early winter)
See easy peazy... Heater and and Cooling were defined by the previous author as his ports for his heater and fan. Simply change those to be the ports you want to use or you can define them like this
#define Heater Port7
That was too easy, lol. I should have been able to figure that out. Thanks again!
No problem, sometimes the easy things are hardest to figure out. You've out together quite a few things so far! Quite impressive
