Hi all,
I want to connect my Jebao DC12000 to my RA. Jebao and RA cable I have. As far as I know I should connect it to my relay actinic channel (I will connect to third relay). The thing is I need help with the code:
1) what code should I write to control Jebao DC pump from third relay expansion actinic channel?
2) How to control the speed of Jebao DC pump from Android app which will be connected to my third relay expansion module?
Thanks in advance.
Jebao DC pump control
Re: Jebao DC pump control
I'm at work, or I could whip something up.
Otherwise, you could just run the Wizard to generate the code and then just cut and paste the bit you need into your code.
With the app, you should just be able to long press on the actinic % to override the value.
Yeah I know that, but it will be connected to 3rd relay, it does not matter in app or code?
Only the dimming ports on the first box work. The dimming ports on the expansion relays are disabled.
Damn :/ there are 3,5 meters to the 1st relay box are any other available options?
Dimming expansion module. It's 6 more dimming ports. You can also get a custom 16 channel one if you like.
But even that will plug into the first relay box.
You can also use the float switch ports (either one if you have an RA+). You'll need to modify the cable to work with 5v, though.
You can go quite far with the dimming cables. Just use speaker wire, hookup wire, pretty much anything that will carry a low voltage signal.Armetas wrote:Damn :/ there are 3,5 meters to the 1st relay box are any other available options?
