all uploads working, testing now for the functionality
including the code for future reference
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit
| Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit
| Port7Bit | Port8Bit;
//ReefAngel.Relay.On( Port7 );
// Set the Lights Overheat probe to be T1
ReefAngel.OverheatProbe = T1_PROBE; // Default: T2_PROBE
// Set the Water Temp probe to be T2, this is used for the StandardHeater and StandardFan functions
ReefAngel.TempProbe = T2_PROBE; // Default: T1_PROBE
ReefAngel.Timer[1].SetInterval(45);
// ReefAngel.StandardATO( Port1,55 );
ReefAngel.StandardHeater( Port2,240,255 );
ReefAngel.StandardLights( Port3,11,5,20,5 );
ReefAngel.StandardLights( Port4,8,5,15,55 );
//The following is the timer for Polario
ReefAngel.StandardLights( Port7,9,5,19,5 );
if (hour()>=10 && hour()<18)
ReefAngel.Wavemaker( Port5,25 );
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,5,19,5,0,100,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(10,5,18,5,0,100,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(11,5,15,35,0,100,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(14,5,17,25,0,100,0) );
ReefAngel.PWM.SetChannel( 4, PWMParabola(18,35,24,5,40,100,40) );
//ReefAngel.PWM.SetChannel( 5, PWMParabola(9,3,20,15,50,100,50) );
//Float #1
if (ReefAngel.IO.GetChannel(1)) // if float 1 is triggered
// ReefAngel.Relay.Off(Port8); // Turn Polario off
ReefAngel.Relay.Off(Port7); // Turn Return off
// BuzzerOn(); // Turn Buzzer on
//Float #2
if (ReefAngel.IO.GetChannel(2)) // if float 2 is triggered
ReefAngel.Relay.On(Port1); // Turn AutoTopOff on
ReefAngel.Timer[1].Start(); // Start/Trigger timer
// Float #3
// if (ReefAngel.IO.GetChannel(3)) // if float 3 is triggered
// Float #4
// if (ReefAngel.IO.GetChannel(4)) // if float 4 is triggered
// ReefAngel.Relay.On(Port7); // Turn Skimmer off
// Float #5
// if (ReefAngel.IO.GetChannel(5)) // if float 5 is triggered
// ReefAngel.Relay.Off(Port8); // Turn Return off
// Timer 1
if (ReefAngel.Timer[1].IsTriggered())
ReefAngel.Relay.Off(Port1); // Turn AutoTopOff off
int x,y;
// Dimming Expansion
x = 14;
y = 6;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 6;
ReefAngel.LCD.DrawText( COLOR_NAVY,DefaultBGColor,x,y,"Ch :" );
ReefAngel.LCD.DrawText( COLOR_NAVY,DefaultBGColor,x+12,y,a );
ReefAngel.LCD.DrawText( COLOR_NAVY,DefaultBGColor,x+24,y,ReefAngel.PWM.GetChannelValue(a) );
y += 10;
// I/O Expansion
byte bkcolor;
x = 27;
y = 47;
for ( int a=0;a<4;a++ )
ReefAngel.LCD.DrawCircleOutline( x+(a*25),y,4,COLOR_NAVY );
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE;
else bkcolor=COLOR_RED;
ReefAngel.LCD.FillCircle( x+(a*25),y,2,bkcolor );
//#if defined DisplayLEDPWM && ! defined RemoveAllLights
//ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params,
//ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue() );
//#else // defined DisplayLEDPWM && ! defined RemoveAllLights
//ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params );
//#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
// Set the starting coordinates for displaying the parameters
x =14;
y = 60;
// Change these values as needed. They are the threshold values
// for the low and high temperatures, respectively. The values do
// not contain decimal points.
int lowTempValue = 240;
int highTempValue = 255;
byte TempColor;
// To make changes for each temp sensor, change the value
// of TempColor to be the appropriate color
// T1 Temperature
if ( ReefAngel.Params.Temp[T1_PROBE] < lowTempValue ) { TempColor = COLOR_BLUE; }
else if ( ReefAngel.Params.Temp[T1_PROBE] > highTempValue ) { TempColor = COLOR_RED; }
else { TempColor = PHColor; }
ReefAngel.LCD.DrawText(TempColor,COLOR_WHITE,x,y,"LEDs:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], TempColor, x+30, y,10);
// T2 Temperature
if ( ReefAngel.Params.Temp[T2_PROBE] < lowTempValue ) { TempColor = COLOR_BLUE; }
else if ( ReefAngel.Params.Temp[T2_PROBE] > highTempValue ) { TempColor = COLOR_RED; }
ReefAngel.LCD.DrawText(TempColor,COLOR_WHITE,x,y+10,"Tank:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], TempColor, x+30, y+10,10);
// T3 Temperature
if ( ReefAngel.Params.Temp[T3_PROBE] < lowTempValue ) { TempColor = COLOR_BLUE; }
else if ( ReefAngel.Params.Temp[T3_PROBE] > highTempValue ) { TempColor = COLOR_RED; }
ReefAngel.LCD.DrawText(TempColor,COLOR_WHITE,x,y+20,"Room:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], TempColor, x+30, y+20,10);
ReefAngel.LCD.DrawText(PHColor,COLOR_WHITE,x+60,y,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x+80, y,100);
// Keep these commented out to remove the DP & AP lines
// DrawText(DPColor,COLOR_WHITE,x+60,y+10,"DP:");
// DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
// DrawText(APColor,COLOR_WHITE,x+60,y+20,"AP:");
// DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+20,1);
ReefAngel.LCD.DrawOutletBox( 14, 95, TempRelay );
ReefAngel.LCD.DrawDate( 6, 120 );
void BuzzerOn()
ReefAngel.PWM.SetActinic((now()%2)*100);
