Main Menu features
Re: Main Menu features
bigHUN wrote:binder : - your highlights removing the entire block not only the DP / AP
You are correct. I misread the block of code when I was looking at it last night. You will need to change it to be this:
  int x,y;
  // Dimming Expansion
  x = 15;
  y = 2;
  for ( int a=0;a<6;a++ )
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 2;
    y += 10;
  // I/O Expansion
  byte bkcolor;
  x = 14;
  y = 39;
    if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE;
    else bkcolor=COLOR_GRAY;
  // Parameters - does not display DP & AP
  ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params );
I updated the code and this should take care of what you are wanting. It displays only the monitor block and not the DP & AP (aka, the PWM percentages).
Question: - I got a new Temp probe to replace the old was leaking still can use it at dry ambient.
No matter how I plug in now both, the old Temp probe gets to the first-top T1 always to show....
is there any internal code or S/N in the probes the RA+ board is recognizing them?
What is a workaround I can use the new Temp probe for water T1 and lights Temp probe for T2 ?
Like sacohen said, you cannot change the serial numbers on the temp probes. If you want to swap the T1 & T2 probes around, you can add these to your setup():
void setup() {
  // Set the Lights Overheat probe to be T1
  ReefAngel.OverheatProbe = T1_PROBE;  // Default:  T2_PROBE
  // Set the Water Temp probe to be T2, this is used for the StandardHeater and StandardFan functions
  ReefAngel.TempProbe = T2_PROBE;  // Default:  T1_PROBE
You're new probe will always be T2 and your old probe will always be T1. So we are just swapping in the code what probe is used for the different sections. If you do not like this idea, then you will just need to physically change how you mount the temp probes and move them around. Otherwise, the code swap is your only software option.
- how to shift the entire thing down couple pixels, because the space between the relay numbers to date/time is too wide but on the top the Chanels have a haircut?
I have seen it earlier and now just can't find it (not sure if was a post or an instructions file), how to program the fonts locations in X and Y axis, because what is on the screen is too much to the upper side and need to move downward couple lines....
This is referenced in the link sacohen earlier. Here's the direct link to the guide that I created about the custom main screen: http://curtbinder.info/ragen/docs/RA_Cu ... Screen.pdf
It details how to draw text on the display with the X,Y coordinates and how to use the fonts, etc.
I think this covers most, if not all, of your questions. Once you get through this stuff, then we can figure out what you have left to finish.
bigHUN
Post by bigHUN »
I have managed to shift the existing text and graphics on the LCD also swap some colors.
Removing the DP and AP didn't work do to an error in upload:
"No matching function to call to RA_NokiaLCD"
Also makes me think if we remove these two there will be a huge empty space, what else may be a good to place there?
  ReefAngel.AddStandardMenu();  // Add Standard Menu
  ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit
| Port8Bit;
  ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit
| Port7Bit | Port8Bit;
  ReefAngel.Relay.On( Port7 );
  ReefAngel.Timer[1].SetInterval(45);
//  ReefAngel.StandardATO( Port1,55 );
  ReefAngel.StandardHeater( Port2,240,255 );
  ReefAngel.StandardLights( Port3,8,5,20,5 );
  ReefAngel.StandardLights( Port4,11,5,15,55 );
  if (hour()>=10 && hour()<18)
    ReefAngel.Wavemaker( Port5,25 );
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
  ReefAngel.PWM.SetChannel( 0, PWMParabola(9,5,19,5,1,100,1) );
  ReefAngel.PWM.SetChannel( 1, PWMParabola(10,5,18,5,1,100,1) );
  ReefAngel.PWM.SetChannel( 2, PWMParabola(11,5,15,35,1,100,1) );
  ReefAngel.PWM.SetChannel( 3, PWMParabola(14,5,17,25,1,100,1) );
  ReefAngel.PWM.SetChannel( 4, PWMParabola(18,35,24,5,40,100,40) );
  //ReefAngel.PWM.SetChannel( 5, PWMParabola(9,3,20,15,50,100,50) );
  //Float #1
  if (ReefAngel.IO.GetChannel(1)) // if float 1 is triggered
  // ReefAngel.Relay.Off(Port8); // Turn Polario off
    ReefAngel.Relay.Off(Port7); // Turn Return off
  // BuzzerOn(); // Turn Buzzer on
  //Float #2
  if (ReefAngel.IO.GetChannel(2)) // if float 2 is triggered
    ReefAngel.Relay.On(Port1); // Turn AutoTopOff on
    ReefAngel.Timer[1].Start(); // Start/Trigger timer
  // Float #3
  // if (ReefAngel.IO.GetChannel(3)) // if float 3 is triggered
  // Float #4
  // if (ReefAngel.IO.GetChannel(4)) // if float 4 is triggered
  // ReefAngel.Relay.On(Port7); // Turn Skimmer off
  // Float #5
  // if (ReefAngel.IO.GetChannel(5)) // if float 5 is triggered
  // ReefAngel.Relay.Off(Port8); // Turn Return off
  // Timer 1
  if (ReefAngel.Timer[1].IsTriggered())
    ReefAngel.Relay.Off(Port1); // Turn AutoTopOff off
  int x,y;
  x = 15;
  y = 6;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 6;
    ReefAngel.LCD.DrawText( COLOR_NAVY,DefaultBGColor,x,y,"Ch :" );
    ReefAngel.LCD.DrawText( COLOR_NAVY,DefaultBGColor,x+12,y,a );
    ReefAngel.LCD.DrawText( COLOR_NAVY,DefaultBGColor,x+24,y,ReefAngel.PWM.GetChannelValue(a) );
    y += 10;
  // I/O Expansion
  byte bkcolor;
  x = 25;
  y = 43;
  for ( int a=0;a<4;a++ )
    ReefAngel.LCD.DrawCircleOutline( x+(a*25),y,4,COLOR_NAVY );
    else bkcolor=COLOR_RED;
    ReefAngel.LCD.FillCircle( x+(a*25),y,2,bkcolor );
  ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params,
  ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
  ReefAngel.LCD.DrawDate( 6, 120 );
void BuzzerOn()
  ReefAngel.PWM.SetActinic((now()%2)*100);
How can I rename the default Temp colors to let say GREEN (same as the Ph)? If below 24 BLUE and above 25.5 RED
Ok. I forgot about how the DrawMonitor function works. When you have the PWM enabled, you must include the values for DP & AP otherwise you get that error with the function. So, we just have to "un bundle" that function and display the items individually instead of use that function. Besides, in order to do what you want with the multiple colors, you must do it this way.
I've updated the DrawMain function and I'm pretty sure I have it working the way you want it. You will need to experiment with the colors and also if you want all three temp probes to display the same colors. I chose to have both the labels and the values change text color based on your 24.0 and 25.5 values. If we need to change the labels (the T1, T2, T3 words) back to their original colors, that is easy to do.
  int x,y;
  x = 15;
  y = 6;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 6;
    y += 10;
  // I/O Expansion
  byte bkcolor;
  x = 25;
  y = 43;
  // Set the starting coordinates for displaying the parameters
  x = 15;
  y = 53;
  // Change these values as needed. They are the threshold values
  // for the low and high temperatures, respectively. The values do
  // not contain decimal points.
  int lowTempValue = 240;
  int highTempValue = 255;
  byte TempColor;
  // To make changes for each temp sensor, change the value
  // of TempColor to be the appropriate color
  // T1 Temperature
  if ( ReefAngel.Params.Temp1 < lowTempValue ) { TempColor = COLOR_BLUE; }
  else if ( ReefAngel.Params.Temp1 > highTempValue ) { TempColor = COLOR_RED; }
  else { TempColor = PHColor; }
  DrawText(TempColor,COLOR_WHITE,x,y,"T1:");
  DrawSingleMonitor(ReefAngel.Params.Temp1, TempColor, x+18, y,10);
  // T2 Temperature
  if ( ReefAngel.Params.Temp2 < lowTempValue ) { TempColor = COLOR_BLUE; }
  else if ( ReefAngel.Params.Temp2 > highTempValue ) { TempColor = COLOR_RED; }
  DrawText(TempColor,COLOR_WHITE,x,y+10,"T2:");
  DrawSingleMonitor(ReefAngel.Params.Temp2, TempColor, x+18, y+10,10);
  // T3 Temperature
  if ( ReefAngel.Params.Temp3 < lowTempValue ) { TempColor = COLOR_BLUE; }
  else if ( ReefAngel.Params.Temp3 > highTempValue ) { TempColor = COLOR_RED; }
  DrawText(TempColor,COLOR_WHITE,x,y+20,"T3:");
  DrawSingleMonitor(ReefAngel.Params.Temp3, TempColor, x+18, y+20,10);
  DrawText(PHColor,COLOR_WHITE,x+60,y,"PH:");
  DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x+78, y,100);
// Keep these commented out to remove the DP & AP lines
//  DrawText(DPColor,COLOR_WHITE,x+60,y+10,"DP:");
//  DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
//  DrawText(APColor,COLOR_WHITE,x+60,y+20,"AP:");
//  DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+20,1);
To handle the color changing of the temp probes based on the actual temperatures, I update the color used for each temp probe just before I update the display. That is the reason for the conditional statements before i do the DrawText and DrawSingleMonitor functions.
This should hopefully take care of what you want it to do. If you need to shift the position on the screen down some, to fill in some blank spaces, just adjust the y coordinate and it will move it either down or up the screen (depending on how you adjust the y coordinate).
bigHUN
Post by bigHUN »
got an error at upload:
*****"struct ParamsSruct' has no member named 'Temp1'"
*****"DrawText' was not declared in the scope"
Use Temp[T1_PROBE] instead of Temp1
bigHUN
Post by bigHUN »
rimai - I will try that on spare board, right now my laptop is connected to main tank ********Temp[T1_PROBE] instead of Temp1
binder - these command lines didn't gave me error on the spare board, that is good news, but
this may swap the internal calculation I don't know yet, I will let it test for overnight, but still
on the display the T1 (is the upper value) is showing the "old" temp probe with ambient of 20.1C and below the T2 is showing the tank temperatures of 24.6C...............I hope so or I have a fried fish for breakfast...
bigHUN
Post by bigHUN »
I used all Temp[T1_PROBE] instead of Temp1; Temp[T2_PROBE] instead of Temp2; Temp[T3_PROBE] instead of Temp3
gave me an error on line
********'DrawText' was not declared in this scope
bigHUN
Post by bigHUN »
forgot
| Port8Bit;
  //ReefAngel.Relay.On( Port7 );
  ReefAngel.StandardLights( Port3,11,5,20,5 );
  ReefAngel.StandardLights( Port4,8,5,15,55 );
  //The following is the timer for Polario
  ReefAngel.StandardLights( Port7,9,5,19,5 );
  //Float #1
  //Float #2
  // Float #3
  // Float #4
  // Float #5
  // Timer 1
  int x,y;
  x = 15;
  y = 6;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 6;
    y += 10;
  // I/O Expansion
  byte bkcolor;
  x = 25;
  y = 43;
//#if defined DisplayLEDPWM && ! defined RemoveAllLights
  //ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params,
  //ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue() );
//#else // defined DisplayLEDPWM && ! defined RemoveAllLights
  //ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params );
//#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
  x = 15;
  y = 53;
  byte TempColor;
  // T1 Temperature
  if ( ReefAngel.Params.Temp[T1_PROBE] < lowTempValue ) { TempColor = COLOR_BLUE; }
  else if ( ReefAngel.Params.Temp[T1_PROBE] > highTempValue ) { TempColor = COLOR_RED; }
  DrawText(TempColor,COLOR_BLUE,x,y,"T1:");
  // T2 Temperature
  if ( ReefAngel.Params.Temp[T2_PROBE] < lowTempValue ) { TempColor = COLOR_BLUE; }
  else if ( ReefAngel.Params.Temp[T2_PROBE] > highTempValue ) { TempColor = COLOR_RED; }
  // T3 Temperature
  if ( ReefAngel.Params.Temp[T3_PROBE] < lowTempValue ) { TempColor = COLOR_BLUE; }
  else if ( ReefAngel.Params.Temp[T3_PROBE] > highTempValue ) { TempColor = COLOR_RED; }
void BuzzerOn()
yeah, i just realized I forgot to add in a part that will make it work. you need to add
 ReefAngel.LCD.
in front of all the drawtext and drawsinglemonitor lines, like this :
 ReefAngel.LCD.DrawText(...)
ReefAngel.LCD.DrawSingleMonitor(...)
that should hopefully fix it.
Sent from my Moto X
bigHUN
Post by bigHUN »
mind you inserting it for me, not sure I can follow you entirely, and thanks in advance
bigHUN
Post by bigHUN »
rimai, binder THANK YOU FOR THE GREAT HELP
all uploads working, testing now for the functionality
including the code for future reference
| Port8Bit;
  ReefAngel.PWM.SetChannel( 0, PWMParabola(9,5,19,5,0,100,0) );
  ReefAngel.PWM.SetChannel( 1, PWMParabola(10,5,18,5,0,100,0) );
  ReefAngel.PWM.SetChannel( 2, PWMParabola(11,5,15,35,0,100,0) );
  ReefAngel.PWM.SetChannel( 3, PWMParabola(14,5,17,25,0,100,0) );
  //Float #1
  //Float #2
  // Float #3
  // Float #4
  // Float #5
  // Timer 1
  int x,y;
  x = 14;
  y = 6;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 6;
    y += 10;
  // I/O Expansion
  byte bkcolor;
  x = 27;
  y = 47;
  x =14;
  y = 60;
  byte TempColor;
  // T1 Temperature
  ReefAngel.LCD.DrawText(TempColor,COLOR_WHITE,x,y,"LEDs:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], TempColor, x+30, y,10);
  // T2 Temperature
  ReefAngel.LCD.DrawText(TempColor,COLOR_WHITE,x,y+10,"Tank:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], TempColor, x+30, y+10,10);
  // T3 Temperature
  ReefAngel.LCD.DrawText(TempColor,COLOR_WHITE,x,y+20,"Room:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], TempColor, x+30, y+20,10);
  ReefAngel.LCD.DrawText(PHColor,COLOR_WHITE,x+60,y,"PH:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x+80, y,100);
  ReefAngel.LCD.DrawOutletBox( 14, 95, TempRelay );
void BuzzerOn()
My next step is to find the way dimming to dark when the values showing zero
awesome! glad you got it figured out!
Sent from my Moto X
bigHUN
Post by bigHUN »
I am noticing, in relative to the time of the day the display shows either 0 or 100% and nothing in between...
at this moment I am testing the parabola, one day, the other day the slope
(btw the LED's are ramping up in the morning, it is visible how the light increases whenever I am passing by, but at evening there is no ramping down, feels like full power until the timer shots the 5-6 relay ports down)
do we have a known issue?
Maybe you got the wrong times?
Can you post the updated code?
Which channels are your LEDs connected to?
bigHUN
Post by bigHUN »
this last code just couple posts above
#4-5 relays powering the 2+2 dimmers, and these are the four channels from 0-3 feeding the LEDs
(4 is a moonlight and the 5 would be the a cooling fan but the dimming module can't give enough Amps)
Your relay #4 is on from about 8:05am to 3:55pm
Relay #5 is setup as wavemaker for Koralias or something.
But your channels are setup to go all over the place.
Channel 0 is from 9:05am to 7:05pm
Channel 1 is from 10:05am to 6:05pm
Channel 2 is from 11:05am to 3:35pm
Channel 3 is from 2:05pm to 5:25pm
Your code is really confusing.
bigHUN
Post by bigHUN »
sorry not #5
3 and 4 have one of each power cables running to 2+2 ELM's,
{I did rewiring the ELM 60-40 drivers for a manual overdrive for case of emergency and when I finished then I noticed the #3 and #4 powercable swap inside the box, didn't wanted to re-solder again so I just moved the timing....}
I had to go downstairs to my old laptop monitoring the parameters for my testing....here is a current code from the RA+
| Port8Bit;
  //ReefAngel.PWM.SetChannel( 0, PWMParabola(9,5,14,5,0,100,0) );
  //ReefAngel.PWM.SetChannel( 1, PWMParabola(10,5,15,35,0,100,0) );
  //ReefAngel.PWM.SetChannel( 2, PWMParabola(12,5,17,5,0,100,0) );
  //ReefAngel.PWM.SetChannel( 3, PWMParabola(14,5,19,25,0,100,0) );
  //ReefAngel.PWM.SetChannel( 4, PWMParabola(18,35,23,55,0,100,0) );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(9,5,14,5,0,100,20,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(10,5,13,35,0,100,20,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(12,5,17,5,0,100,20,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(14,5,19,25,0,100,20,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(18,35,23,55,0,100,30,0) );
  //Float #1
  //Float #2
  // Float #3
  // Float #4
  // Float #5
  // Timer 1
  int x,y;
  x = 14;
  y = 6;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 6;
    y += 10;
  // I/O Expansion
  byte bkcolor;
  x = 27;
  y = 47;
  x =14;
  y = 60;
  byte TempColor;
  // T1 Temperature
  // T2 Temperature
  // T3 Temperature
void BuzzerOn()
The #4 relay is powering the 2 ELM's with Channels 0 and 1 (one ELM each)
The #3 relay is powering the 2 ELM's with Channels 2 and 3 (one ELM each)
The #4 is a moonlight
#5 is off becuase the expansion module can't support enough Amps to the fans.
8.05 AM relay #4 turns ON, 9.05 Channel 0 comes ON
10.05 Channel 1
11.05 relay #3
and so on
At evening the Channels 2 and 3 are ...looks like full light before turns OFF at 20.05 PM
Right now I am sitting in front of the tank, the RA+ LCD shows me
Channel 0=0; measuring 7.7 Volts on the dimming module port
ch1=0; 7.29V
ch2=0; 7.74V
ch3=100; 5.49V
ch4=0; 8.0V
ch5=0; 7.9V
but the LED channels 2 and 3 are ON both, can't say full light but almost
bigHUN
Post by bigHUN »
18 minutes after midnight, a quick look at the RA+
ch0=0 10.64 Volt on the expansion module port
ch1=0 10.64 V
ch2=0 10.64 V
ch3=00 5.78 V
ch4=000 8.6 V
Is this normal? Also, finding it interesting the number of zeros........
Are you sure the time is set properly on your RA?
bigHUN
Post by bigHUN »
How you mean "time is set properly"?
AM and PM is right, the RA clock is in sync to PC, what else is there?
That's pretty much it... just not sure why you should have full voltage on the dimming channels at midnight...
bigHUN
Post by bigHUN »
does the number of digits for zero's have anything to do with it?
{0 -or- 00 -or- 000}
right now is 3.40 pm in my PC and the RA+ is late 3 minutes (last time they were synced 3 days ago), today I am running the slope from the same program above
ch0 = 00
ch1 = 000
ch2 = 800
ch3 = 77
ch4 = 0
ch5 = 980
The 0s are the remaining of the 100 that was previously drawn in the screen.
Your custom screen is not clearing the zeros. If you click the joystick to enter menu and exit it out, it will force a full refresh in the screen, which clears the zeros.
bigHUN
Post by bigHUN »
any work around possible with 0 Volts to ram up to 10V and back to 0 Volts on the dimming module?
bigHUN
Post by bigHUN »
So I can assume the dimming expansion module is "as is" ?
There should be no issue going 0V-10V-0V. Try loading the controller test code.
bigHUN
Post by bigHUN »
"controller test code"
Where can I find it, what and how to do it to post back?
