*new user* Setup to control Jebao wavemaker remotely
Ask in here.
SlimyEel
Post by SlimyEel »
Just received my reef angel controller this week, have it all setup, except for being able to control my jebao wavemaker with the app. I can control the speed via the dimming port. But on the IOS app, it has the option to change different settings, speeds and duration, which do not allow me to change them.
Can someone please tell me what I need to do to enable this. I apologize if this is such a newbie question. :oops:
I have read on the forum as much as I could make out, but unable to determine exactly what I need to do. Good news is this is the only thing I have left to have the controller the way I want it.... for now at least.
Thanks for any help you guys can offer.
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
// Define labels for 2014 LCD screen
ReefAngel.CustomLabels[0]="Metal Halide";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="Return";
ReefAngel.CustomLabels[3]="BP Reactor";
ReefAngel.CustomLabels[4]="Skimmer";
ReefAngel.CustomLabels[5]="JBJ ATO";
ReefAngel.CustomLabels[6]="Wavemaker";
ReefAngel.CustomLabels[7]="Moon Light";
ReefAngel.MHLights( Port1,15,0,0,0,10 );
ReefAngel.StandardHeater( Port2,780,785 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,1,0,15,100,120,15) );
ReefAngel.DCPump.SetMode( Else,50,10 );
ReefAngel.Portal( "SlimyEel" );
Re: *new user* Setup to control Jebao wavemaker remotely
Post your code please
Something is weird.
You are using daylight channel for LEDs and Jebao according to your code.
SlimyEel
Post by SlimyEel »
Ok, I believe part of my problem is confusion with the initial setup. When I was using the Wizard initially, I set the dimming port up because I thought it controlled the Jebao wavemaker, thus I would need to say it was in use.
I do not run led's on a dimmer, I only use a main metal halide, and led moonlights (which are not on a dimmer).
So should I not have the dimmer setup, and the Jebao would use the daylight dimmer port automatically?
SlimyEel
Post by SlimyEel »
Inevo/Roberto:
Just wanted to let you guys know that that fixed it. It was just my misunderstanding on initial setup. I didn't need to tell it that I was using the Dimming Port on the screen prior to the setup of the wavemaker setup. I changed my code to this:
BTW, I can not believe how incredibly simple that was, I was thinking it must be more complicated :roll: . I love this, I cant believe how cool this is, being able to change the settings from my ipad and iphone. Absolutely incredible.
Thanks again, now I am fully setup for everything I wanted a controller to do. Now I now I am just going to continue to advance it to do more "custom" things!
This forum is very helpful and you guys have been great.
Thank again.
Roberto, that should be your new tagline. "Reef Angel, so easy even an eel can do it!" :mrgreen:
Glad it's working for you!
Since you have UseMemory=true the mode you are setting in the code will not be used btw. Only what is set in the internal memory section in the portal.
SlimyEel
Post by SlimyEel »
Ok I was thinking I prefer it this way, I prefer to control everything from the app/ portal
Yes by far the better way, I just didn't want you getting confused since you have this in your code.
It will get overwritten when the RA reads internal memory later on.
