Put this up in globals:
byte DaylightPWMValue=0; // For cloud code
boolean FireInTheHole=false; // True if trigger has been sent
byte TriggerChannel=1; // Dimming expansion channel to look for lightning trigger
byte Trigger=150; // Value sent to RANet Dimming module to trigger lightning strikesCode: Select all
// Cloud/lightning lighting control
ReefAngel.PWM.Channel0PWMSlope(30); // Set actinic channel
DaylightPWMValue=PWMSlope(10,30,22,00,0,100,60,0);
CheckCloud(); // Check to see if it's time for a cloud/lightning
if (!FireInTheHole) ReefAngel.PWM.SetChannel(1,DaylightPWMValue); // Whites are on channel 1Here are the functions you will need to add to your code to produce the clouds and lightning. Add this to the very end past the last }.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 4
#define Start_Cloud_After NumMins(12,00)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resuls could happen.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Slow, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega2,Mega,Mega,Calm};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
WriteTrigger();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
WriteTrigger();
break;
case Fast:
WriteTrigger();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
else x=75;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
void WriteTrigger()
FireInTheHole = true;
ReefAngel.PWM.SetChannel(TriggerChannel, Trigger);
The RANet receiver itself must be reprogrammed. Remove the RANet receiver from the dimming expansion module.
Notice the bottom row of 6 pins marked JP2. You will need to connect your RA programming cable to here. The black wire goes to the left side on the pin marked GND. Load up the RA Arduino program. Under Tools -> Board, select "Reef Angel Controller w/ optiboot". Select the appropriate serial port as well. Load in the following code and upload to the RANet receiver.
#include <avr/eeprom.h>
#define BLUE_LED 9
#define WHITE_LED 10
#define BLUE_INTENSITY 255
#define WHITE_INTENSITY 255
#define RANET_MAX_SIZE 64
#define DISCONNECT_TIMEOUT 2000
#define LastFallback0 100 // Memory location for fallback storage
#define RANet_Down 0
#define RANet_OK 1
byte Trigger=150; // Trigger value for lightning effect
byte TriggerChannel=1; // Channel to look for the trigger on
byte buffer_index;
byte buffer[128];
char buf[3];
byte bufint, bufsize;
byte RANetData[RANET_MAX_SIZE];
byte RANetCRC;
byte BlueChannel=0;
byte WhiteChannel=0;
byte RANet_Status=RANet_Down;
boolean cable_present=false;
unsigned long lastmillis=millis();
unsigned long lastcablecheck=millis();
pinMode(BLUE_LED,OUTPUT);
pinMode(WHITE_LED,OUTPUT);
Serial.begin(57600);
Wire.onReceive(NULL);
Wire.onRequest(NULL);
Wire.begin();
for (int a=0;a<RANET_MAX_SIZE; a++) // Clear array
RANetData[a]=0;
Wire.beginTransmission(0x68);
Wire.write(0);
int a=Wire.endTransmission();
cable_present=(a==0);
// setup PCA9685 for data receive
// we need this to make sure it will work if connected ofter controller is booted, so we need to send it all the time.
Wire.beginTransmission(0x40);
Wire.write(0);
Wire.write(0xa1);
if (cable_present)
BlueChannel=100;
WhiteChannel=0;
analogWrite(WHITE_LED,WHITE_INTENSITY*WhiteChannel/100);
analogWrite(BLUE_LED,BLUE_INTENSITY*BlueChannel/100);
BlueChannel=0;
WhiteChannel=0;
while(Serial.available())
UpdateWhiteChannel();
char c = Serial.read(); // Read each incoming byte
buffer[buffer_index]=c; // store in the buffer array
if (c==10) // if line feed we analyze the payload
if (buffer_index>25) // only need to analyse if buffer_index is greater than 25, otherwise the payload is broken or corrupt
if (buffer_index==buffer[1]) // check if payload matches the length the controller sent
RANetCRC=0;
for (int a=0; a<(buffer_index-2); a++) // calculate CRC
RANetCRC+=buffer[a];
if (RANetCRC==buffer[buffer_index-2]) // if CRC matches
for (int a=0; a<(buffer_index-2); a++) // Copy buffer to RANetData
RANetData[a]=buffer[a];
// Serial.print(millis());
// Serial.print("\t");
// Serial.println(RANetData[2]);
for (int a=0;a<8;a++)
if (eeprom_read_byte((unsigned char *) LastFallback0+a)!=RANetData[10+a])
eeprom_write_byte((unsigned char *) LastFallback0+a, RANetData[10+a]);
Wire.beginTransmission(0x38+a);
Wire.write(~RANetData[2+a]);
// Check for lightning trigger
if (RANetData[18+TriggerChannel] == Trigger) Lightning();
else // If the trigger has not been sent
for (int a=0;a<6;a++) // send along the data
int newdata=(int)(RANetData[18+a]*40.95);
Wire.write(0x8+(4*a));
Wire.write(newdata&0xff);
Wire.write(newdata>>8);
RANet_Status=RANet_OK;
buffer_index=255; // reset buffer index
if (buffer_index++>=128) buffer_index=0; // increment index of buffer array. reset index if >=128
if (millis()-lastmillis>DISCONNECT_TIMEOUT)
// Serial.println("Disconnected");
// Serial.println(RANetData[10]);
Wire.write(~eeprom_read_byte((unsigned char *) LastFallback0+a));
if (RANet_Status==RANet_Down)
BlueChannel=0;
WhiteChannel=millis()%2000<1000?0:100;
void UpdateWhiteChannel()
WhiteChannel=sin(radians((millis()%7200)/40))*255;
BlueChannel=255-(sin(radians((millis()%7200)/40))*255);
analogWrite(WHITE_LED,WhiteChannel);
analogWrite(BLUE_LED,BlueChannel);
void Lightning()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off
newdata=0;
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
//00301200000000000000050000000000000000000000000047
//01301200000000000000050000000000000000000000000048
//02301200000000000000050000000000000000000000000049
//0330120000000000000005000000000000000000000000004a
