New DCPump Modes - How to code???
Re: New DCPump Modes - How to code???
I uncommented the GyreModes and uploaded your code to one of my RA+ units. I manually changed the time to 1400 and 1900 and it worked both times.
The only thing I can recommend is doing an un-install/re-install of the the RA software on your computer. Maybe you have a corrupted library.
The only potential problem I see is that between 1400 and 1500 you have both pumps set to sync. That means they will both be on for 10 minutes and off for 10 minutes at the same time.
Ok I will change sync
Will try to do a clean install
Reinstall did not work?
Is there something in the registry to delete?
Upload this code and see what you get:
It worked for me.
ReefAngel.PWM.SetDaylight (GyreMode(40,100,10,true) ); // Short pulse at 60% with 200m
ReefAngel.PWM.SetActinic(GyreMode(40,100,10,false) ); // Short pulse at 60% with 200ms pulse on anti-sync mode
To Close this out:
Uninstalled and resinstalled Arduino application, did this twice. Then reinstalled once again last night and it worked?? No idea why it just worked.
Are these DCPump codes meant for a single pump? How do I code for 2 pumps connected to the Actinic and DayLight channels?cosmith71 wrote:They're easy if you're using the DCPump libraries already.
Generates a random flow from midpoint-offset to midpoint+offset. For example, if you use:Code: Select all
ReefAngel.DCPump.SetMode(Else,midpoint,offset);
You'll get a random flow that ranges between 30 and 70.Code: Select all
ReefAngel.DCPump.SetMode(Else,50,20);
Generates a long, slow sine wave. Speed is the max speed, duration (in minutes), and threshold is the minimum speed. If you leave off threshold it will use 30 (or whatever you have set with DCPump.Threshold).Code: Select all
ReefAngel.DCPump.SetMode(Gyre,speed,duration,threshold);
I'm not familiar with Sine. Maybe someone else can chime in.
Dr Davaraj
You will have lines like this in the setup section of your code
If you want to disable one channel you can set it to None.
If you want both pumps to do the same thing then set them both to Sync.
I have recoded like this. I do havelnevo wrote:You will have lines like this in the setup section of your code
In the setup section.
///////Place your custom code below here
if (hour()>=4 && hour()<8)
ReefAngel.DCPump.SetMode(Sine, 30, 40);
else if (hour()>=8 && hour()<12)
ReefAngel.DCPump.SetMode(TidalSwell, 55); // TidalSwell at 55%
else if (hour()>=12 && hour()<16)
ReefAngel.DCPump.SetMode(millis();1200>750?50:0);
else if (hour()>=16 && hour()<19)
ReefAngel.DCPump.SetMode(LongPulse, 0, 50, 10); // Long pulse at 0% to 50% with 10s pulse
else if (hour()>=19 && hour()<23)
ReefAngel.DCPump.SetMode(Else, 40, 10); // ElseMode 40 +/- 10%
ReefAngel.DCPump.SetMode(Gyre, 30, 50, 10); //GyreMode from 30% to 50% for 10 minutes
When I run 'verify' code it compiles, except for:
ReefAngel.DCPump.SetMode(TidalSwell, 55); and
When I insert this:
ReefAngel.DCPump.SetMode(TidalSwell, 55, true); it compiles for this mode. However 'millis' gives errors. How do I code for millis (standing wave like W1 in Jebao controller)?
You need 3 arguments to SetMode separated by a comma. Mode Speed and Duration. The first only has 2 and no comma and the second, that code block represents one argument and it represents a speed.ReefAngel.DCPump.SetMode(TidalSwell 55); and
Try this:
ReefAngel.DCPump.SetMode(TidalSwell,55,0);
ReefAngel.DCPump.SetMode(Constant,millis();1200>750?50:0,0);
You could also use ShortPulse mode. It's like LongPulse but with duration in ms.
Lee,lnevo wrote:You need 3 arguments to SetMode separated by a comma. Mode Speed and Duration. The first only has 2 and no comma and the second, that code block represents one argument and it represents a speed.ReefAngel.DCPump.SetMode(TidalSwell 55); and
Try this:
I realised I had missed the comma in all the wave settings when I posted this on the forum. In my laptop the commas are there. I'll insert codes for TidalSwell and millis and let you know how it compiles and runs the pumps.
Thank you very much.
Dr Davaraj
Try this:
ReefAngel.DCPump.SetMode(Constant,millis();1200>750?50:0,0); gives error, but
ReefAngel.DCPump.SetMode(Constant,millis()%1200>750?50:0,0); compiles without error.
Should be millis()% i copied and pasted and didnt notice the mistake. Good catch
I have this code set for Else mode.
So the pump should ramp up and down from 30% to 70%, randomly. However, mine goes from 30% to 90% . Is there something wrong with the code or is that how the pump will work?
Dr Davaraj
Dr Davaraj
The DCPump defaults for ElseMode is going to be equal to the speed. So for 50 it will be 50. For anything greater than 50, the speed will be 100-speed.
case Else:
int offset = DCPump.Speed;
if (DCPump.Speed > 50) offset = 100 - DCPump.Speed;
SyncSpeed=ElseMode(DCPump.Speed,offset,true);
AntiSyncSpeed=ElseMode(DCPump.Speed,offset,false);
break;
That's not really how it's intended to work. The range should be speed plus or minus offset.
AlanM added ElseMode to the libraries. And yes, I agree with you Colin. What do you think would be a good defaults for ElseMode in the libraries? We can easily modify this.
ReefAngel.DCPump.UseMemory=false;rimai wrote:Are you using memory settings set to true or false?
I've got a fix for it. I'll submit it shortly.lnevo wrote:AlanM added ElseMode to the libraries. And yes, I agree with you Colin. What do you think would be a good defaults for ElseMode in the libraries? We can easily modify this.
Anyone have any follow up on this? I am having this same problem.
