Was thinking about using this code to turn off skimmer when float switch in cup is triggered
ReefAngel.Relay.Off(Port2);
ReefAngel.Relay.On(Port2);
Only problem I have is if I pull off cup to clean and empty will it turn that relay back on?
If so how can I code it to keep it off till after my cup is cleaned?
Skimmer stop on high ato
Re: Skimmer stop on high ato
You may be able to MaskOff(Port2); if your on the dev code and if I added the function
Thanks.. I'll try override first
Good plan. I still need to add those functions
