previous is fine, but as today i connected with new salinity module and changed ports sequence. my relay box act very strange as shutdown randomly or sometime flash on as well.
im not sure is there any problem with my code as shown below. (checked relay box, dimming expansion, or RA + works fine individually)
// Define Relay Ports by Name
#define Return 1
#define ATOPump 2
#define Skimmer 3
#define ZeovitShake 4
#define Wavepump1 5
#define Wavepump2 6
#define Relay_Box2 7
#define Heater 8
#define T5_Channel1 Box1_Port1
#define T5_Channel2 Box1_Port2
#define T5_Channel3 Box1_Port3
#define ZEO_ST3 Box1_Port4
#define ZEO_SP Box1_Port5
#define CaHCO3 Box1_Port6
#define ZEO_BB Box1_Port7
#define ZEO_KB Box1_Port8
// Define Custom Memory Locations
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port8Bit;
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Wavepump1);
ReefAngel.Relay.On(Wavepump2);
ReefAngel.Relay.On(Relay_Box2);
ReefAngel.CustomLabels[0]="ReturnPump";
ReefAngel.CustomLabels[1]="ATOPump";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="ZeovitShake";
ReefAngel.CustomLabels[4]="WavePump1";
ReefAngel.CustomLabels[5]="WavePump2";
ReefAngel.CustomLabels[6]="Relay_Box2";
ReefAngel.CustomLabels[7]="Heater";
//single ATO
ReefAngel.SingleATO(true,ATOPump,90,1);
ReefAngel.StandardHeater(Heater);
ReefAngel.Relay.DelayedOn(Skimmer);
// T5 light setup
//ReefAngel.MoonLights(LunaLED);
ReefAngel.DosingPumpRepeat1(ZeovitShake);
ReefAngel.StandardLights(T5_Channel2);
ReefAngel.PWM.SetChannel(0,ReefAngel.Relay.Status(T5_Channel1)*100);
ReefAngel.DayLights(T5_Channel1);
ReefAngel.PWM.SetChannel(1,ReefAngel.Relay.Status(T5_Channel3)*100);
ReefAngel.ActinicLights(T5_Channel3);
ReefAngel.PWM.SetChannel(2,ReefAngel.Relay.Status(T5_Channel2)*100);
//dosing pump setup
if (hour()==22 && minute()==31 && second()<26) //Dosing ST3 at 22:31
ReefAngel.Relay.On(ZEO_ST3);
else if (hour()==6 && minute()==31 && second()<26) //Dosing ST3 at 6:31
ReefAngel.Relay.Off(ZEO_ST3);
ReefAngel.PWM.SetChannel(3,ReefAngel.Relay.Status(ZEO_ST3)*100);
if (hour()==22 && minute()==32 && second()<50)
ReefAngel.Relay.On(ZEO_SP);
ReefAngel.Relay.Off(ZEO_SP);
ReefAngel.PWM.SetChannel(4,ReefAngel.Relay.Status(ZEO_SP)*100);
ReefAngel.DosingPumpRepeat2(CaHCO3);
ReefAngel.PWM.SetChannel(5,ReefAngel.Relay.Status(CaHCO3)*100);
//wave pump setup
if (now() % SECS_PER_DAY >= 8 * SECS_PER_HOUR && now() % SECS_PER_DAY < (8 * SECS_PER_HOUR + 10 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(Lagoon,60,20);//Set 6105 to 60% speed with pulse in Lagoon Mode from 9:00~9:10
else if (now() % SECS_PER_DAY >= (8 * SECS_PER_HOUR + 10 * SECS_PER_MIN) && now() % SECS_PER_DAY < (10 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(TidalSwell,60,20); //Set 6105 to 55% speed with 20ms pulse in Tidal Swell Mode
else if (now() % SECS_PER_DAY >= (10 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now() % SECS_PER_DAY < (11 * SECS_PER_HOUR + 10 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(LongPulse,55,15);//Set 6105 to 60% speed with pulse in ReefCrest Mode
else if (now() % SECS_PER_DAY >= (11 * SECS_PER_HOUR + 10 * SECS_PER_MIN) && now() % SECS_PER_DAY < (12 * SECS_PER_HOUR + 0 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(ReefCrest,60,20);;//Set 6105 to 55% speed with Long pulse Mode
else if (now() % SECS_PER_DAY >= (12 * SECS_PER_HOUR + 0 * SECS_PER_MIN) && now() % SECS_PER_DAY < 15 * SECS_PER_HOUR )
ReefAngel.DCPump.SetMode(TidalSwell,55,20); //Set 6105 to 45% speed with 20ms pulse in Tidal Swell Mode
else if (now() % SECS_PER_DAY >= 15 * SECS_PER_HOUR && now() % SECS_PER_DAY < (17 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(ReefCrest,60,20);//Set RW8 to 40% speed with Lagoon Pulse Mode
else if (now() % SECS_PER_DAY >= (17 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now() % SECS_PER_DAY < (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN))
ReefAngel.DCPump.SetMode(ShortPulse,70,34);//Set 6105 to 65% speed with ShortPulse Mode
else if (now() % SECS_PER_DAY >= (18 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now() % SECS_PER_DAY < (19 * SECS_PER_HOUR + 00 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(Lagoon,60,20);//Set 6105 to 55% speed with pulse in Lagoon Mode
else if (now() % SECS_PER_DAY >= (19 * SECS_PER_HOUR + 0 * SECS_PER_MIN) && now() % SECS_PER_DAY < 20 * SECS_PER_HOUR )
ReefAngel.DCPump.SetMode(TidalSwell,50,20); //Set 6105 to 85% speed with 20ms pulse in Tidal Swell Mode
else if (now() % SECS_PER_DAY >= 20 * SECS_PER_HOUR && now() % SECS_PER_DAY < (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(ReefCrest,55,20);//Set 6105 to 70% speed with Lagoon Pulse Mode
else if (now() % SECS_PER_DAY >= (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now() % SECS_PER_DAY < (22 * SECS_PER_HOUR + 35 * SECS_PER_MIN) )
ReefAngel.DCPump.SetMode(Lagoon,70,20);//Set 6105 to 90% speed with pulse in Lagoon Mode, dossing coral feed.
ReefAngel.DCPump.SetMode(NutrientTransport,35,30);
static unsigned long feeding;
if (now()-feeding< 1 *SECS_PER_HOUR) {
//Autofeeder
if ( ((hour() == 18)) && (minute() == 58) &&(second() == 30) ) ReefAngel.FeedingModeStart();
if ( ((hour() == 9)) && (minute() == 28) &&(second() == 0) ) ReefAngel.FeedingModeStart();
if ( ((hour() == 14)) && (minute() == 28) &&(second() == 0) ) ReefAngel.FeedingModeStart();
//Skimmer off 1.5 hours when coral feeding.
if (now()%SECS_PER_DAY >= (22 * SECS_PER_HOUR + 30 * SECS_PER_MIN) && now()%SECS_PER_DAY < (23 * SECS_PER_HOUR + 30 * SECS_PER_MIN) )
ReefAngel.Relay.Off(Skimmer);
// Power Outage - turn off everything
// Turn off Skimmer if Return pump has been shutoff.
if (!ReefAngel.Relay.Status(Return)) {
ReefAngel.Relay.Off(Heater);
ReefAngel.Portal( "sesame");
