ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.LightsOnPortsE[0] = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 815 );
ReefAngel.Relay.On( Port3 );
ReefAngel.SingleATO( true,Port1,120,10 );
ReefAngel.StandardLights( Port2,19,0,7,0 );
ReefAngel.StandardLights( Port4,10,0,20,0 );
ReefAngel.StandardLights( Port5,6,0,22,0 );
ReefAngel.StandardHeater( Port6,780,805 );
ReefAngel.Relay.DelayedOn( Port7,5 );
ReefAngel.Relay.DelayedOn( Port8,3 );
ReefAngel.DosingPumpRepeat( Box1_Port3,0,60,170 );
ReefAngel.StandardLights( Box1_Port7,13,0,17,0 );
ReefAngel.StandardLights( Box1_Port8,12,0,18,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(13,0,16,0,10,80,10) );
ReefAngel.PWM.SetActinic( PWMSlope(10,0,18,0,15,95,80,15) );
if ((now()%SECS_PER_DAY==28800)) //if it is 8 AM
{ReefAngel.FeedingModeStart(); //START FEEDING MODE}
if ((now()%SECS_PER_DAY==64800)) //if it is 6 PM
ReefAngel.Portal( "Spotted" );
Dimming Signal
Wifi Attachment
Relay Expansion Module
2014 Main Screen
Simple Menu
sketch_jan21a.cpp: In function 'void loop()':
sketch_jan21a:124: error: a function-definition is not allowed here before '{' token
sketch_jan21a:158: error: a function-definition is not allowed here before '{' token
sketch_jan21a:190: error: expected `}' at end of input
Binary sketch size: 56,450 bytes (of a 258,048 byte maximum)
Thanks Guys!!
