Turn off ATO if waterlevel > than 150
Ask in here.
Smotz
Post by Smotz »
Hi all,
Will this code work during water change mode? If not, what do I have to do to make it work during any mode?
//just to be safe if the water level gets to 150 or greater, override the topoff.
    if ( ReefAngel.WaterLevel.GetLevel(1) > 155 && ReefAngel.WaterLevel.GetLevel(2) >155 ) ReefAngel.Relay.Override (Topoff,0);
// End Main Top Off
Re: Turn off ATO if waterlevel > than 150
Should be fine. Only issue is what is the normal water level during WC
Smotz
Post by Smotz »
lnevo wrote:Should be fine. Only issue is what is the normal water level during WC
I'll figure that out - just wanted to make sure the syntax is correct.
The usage would be - I manually turn on my ATO pump (located in the basement) to pump in water (a valve switches to salt water instead of RO). I want to make sure it stops at a certain point if I do not stop it manually.
So you need the code for wc mode?
  if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
    // End Main Top Off
Smotz
Post by Smotz »
    // End Main Top Off
Actually, I would like it to stop filling whether it is in the waterchange mode or not. Would the code work in all modes?
Then stick with your previous code. It should be fine.
You will have to manually clear the override or you'll need an else to put it back to auto...
otherwise change the override function to a simple Off one.
Smotz
Post by Smotz »
lnevo wrote:You will have to manually clear the override or you'll need an else to put it back to auto...
thanks man. Will do.
