cgonser
Posts: 45 Joined: Mon Feb 25, 2013 3:54 pm
Post
by cgonser » Sat Jan 24, 2015 10:31 am
Here is what I am trying to achieve and dont seem to be able to get it right....
First I want to keep my tank between 78-81 degrees, when I tried to set that up, my heater wont turn on at all.
Second, I want my daylights (my whites and blues are on same channel) to come on at 7am and off at 10pm, and I want my refugium to be opposite. Any help would be great!
ReefAngel.Relay.On( Port4 );
ReefAngel.MoonLights( Port2 );
ReefAngel.DayLights( Port7 );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
ReefAngel.DCPump.ExpansionChannel[1] = AntiSync;
ReefAngel.Portal( "cgonser" );
Posts: 12881 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Sat Jan 24, 2015 10:56 am
I would recommend using the wizard and choosing hard coded settings.
cgonser
Post
by cgonser » Sat Jan 24, 2015 11:20 am
That was with the wizard.
Post
by rimai » Sat Jan 24, 2015 12:09 pm
yes, but choose hard coded instead of internal memory.
It may be that your settings in the internal memory are not what you think and we can't troubleshoot if the settings are not hard coded.
cgonser
Post
by cgonser » Sat Jan 24, 2015 5:19 pm
Ok, I did it the other way and not internal....my lights just shut off... HELP Please
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.SingleATO( true,Port1,1200,0 );
ReefAngel.StandardLights( Port2,9,0,19,0 );
ReefAngel.StandardHeater( Port3,778,803 );
ReefAngel.StandardLights( Port7,9,0,19,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,5,80,5) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,5,80,5) );
ReefAngel.DCPump.SetMode( LongPulse,100,10 );
Post
by rimai » Sat Jan 24, 2015 5:40 pm
What time is your controller showing?
cgonser
Post
by cgonser » Sat Jan 24, 2015 5:46 pm
Its actually showing an hour fast, but thats still not lights out time
I went back to "internal" changed nothing else and lights are back on schedule
Post
by rimai » Sat Jan 24, 2015 5:46 pm
What time is it showing on the screen?
cgonser
Post
by cgonser » Sat Jan 24, 2015 6:08 pm
right now 9:07pm
Post
by rimai » Sat Jan 24, 2015 6:13 pm
Well, according to your code, your lights go off at 7pm.
cgonser
Post
by cgonser » Sat Jan 24, 2015 6:16 pm
How do I fix it, thats not the times I set the wizard up as
cgonser
Post
by cgonser » Sat Jan 24, 2015 6:23 pm
Also, my lights aren't ran off port 7
Post
by rimai » Sat Jan 24, 2015 6:43 pm
Make sure to go through the wizard and set the correct ports.
It seems you are choosing the wrong ones.
