Doesnt seem to be doing what I want! HELP?
cgonser
Post by cgonser »
Here is what I am trying to achieve and dont seem to be able to get it right....
First I want to keep my tank between 78-81 degrees, when I tried to set that up, my heater wont turn on at all.
Second, I want my daylights (my whites and blues are on same channel) to come on at 7am and off at 10pm, and I want my refugium to be opposite. Any help would be great!
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.SingleATOLow( Port1 );
    ReefAngel.MoonLights( Port2 );
    ReefAngel.DayLights( Port7 );
    ReefAngel.DCPump.ExpansionChannel[0] = Sync;
    ReefAngel.DCPump.ExpansionChannel[1] = AntiSync;
    ReefAngel.Portal( "cgonser" );
Re: Doesnt seem to be doing what I want! HELP?
I would recommend using the wizard and choosing hard coded settings.
cgonser
Post by cgonser »
That was with the wizard.
yes, but choose hard coded instead of internal memory.
It may be that your settings in the internal memory are not what you think and we can't troubleshoot if the settings are not hard coded.
cgonser
Post by cgonser »
Ok, I did it the other way and not internal....my lights just shut off... HELP Please
    InternalMemory.OverheatTemp_write( 840 );
    ReefAngel.SingleATO( true,Port1,1200,0 );
    ReefAngel.StandardLights( Port2,9,0,19,0 );
    ReefAngel.StandardHeater( Port3,778,803 );
    ReefAngel.StandardLights( Port7,9,0,19,0 );
    ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,5,80,5) );
    ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,5,80,5) );
    ReefAngel.DCPump.SetMode( LongPulse,100,10 );
What time is your controller showing?
cgonser
Post by cgonser »
Its actually showing an hour fast, but thats still not lights out time
I went back to "internal" changed nothing else and lights are back on schedule
What time is it showing on the screen?
cgonser
Post by cgonser »
right now 9:07pm
Well, according to your code, your lights go off at 7pm.
cgonser
Post by cgonser »
How do I fix it, thats not the times I set the wizard up as
cgonser
Post by cgonser »
Also, my lights aren't ran off port 7
Make sure to go through the wizard and set the correct ports.
It seems you are choosing the wrong ones.
