ATO Reservoir refill
Spotted
Post by Spotted »
OK, I've got an i/o expansion and a power control expansion. I have 12v water solenoids that I want to automate the refill of an ATO reservoir with float valves. I know I need a low float to start it then a hi float to stop it, just like an ATO routine. I have no idea how to code this.
I currently have a single float ATO and I want to change it to a dual float ATO. Will this be a problem with the ATO reservoir refill being the basic same ATO type?
I also want to semi automate a water change bin refill. I want to fill a Brute trash can with fresh R/O. Again, I've got it on a 12V water solenoid. I want to be able to manually turn it on then have it fill until it trips a float valve at the top. I also want to put in a low float valve so that it won't fill again if it is already full.
I read somewhere here that the 12 v power controller acts like a relay expansion. I tried adding it in the Wizard, but it only lets you add 2 relays. I currently have 2 relays and the PCE would be a third. What can I do.
Here is my current code.
    ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] = Port2Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port2Bit;
    ReefAngel.LightsOnPorts = Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
    // Use T3 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 805 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.SingleATO( true,Port1,120,10 );
    ReefAngel.StandardLights( Port2,19,0,7,0 );
    ReefAngel.StandardLights( Port5,6,0,22,0 );
    ReefAngel.StandardHeater( Port6,780,805 );
    ReefAngel.Relay.DelayedOn( Port7,5 );
    ReefAngel.Relay.DelayedOn( Port8,3 );
    ReefAngel.DosingPumpRepeat( Box1_Port3,0,60,170 );
    if ((now()%SECS_PER_DAY==28800)) //if it is 8 AM
    {ReefAngel.FeedingModeStart();} //START FEEDING MODE
    if ((now()%SECS_PER_DAY==64800)) //if it is 6 PM
    ReefAngel.Portal( "Spotted" );
Help?
Re: ATO Reservoir refill
You would need to code the ports manually.
The wizard only has capability to only one expansion box.
You can generate a test code with the wizard and just copy and paste to your code.
For example, the code would generate something like this:
ReefAngel.SingleATO( true,Box1_Port1,120,10 );
And you just need to replace to this:
ReefAngel.SingleATO( true,Box2_Port1,120,10 );
