Any updates?jegillis wrote:I will just get the 6000 from amazon, easy return if it doesn't work out and no duties or brokerage charges. Last time I got a $25 car part from the UK UPS charged me $130 in brokerage charges for the inconvenience of prepaying $2.50 in duty charges. I will order the stuff this week and see how it goes.
Code for DC return pump
Re: Code for DC return pump
Not on the DCT, but my DC6000 works perfect with the code that was in this thread.
An interesting note, when I used the DC6000 controller, 4 light out of 6 was getting my overflow to 98%. I thought it will be equal to 66% in the reef angle code. After playing a bit 77% gets me to 67% in the overflow. I am fine with it, since the waterfall sound is not very bad. I learned that you need to play with the control to find the best for each case.
http://forum.reefangel.com/status/banne ... nWolf&t=-8
Onur
Onur
Sorry been busy the last few days with girl scout camping...I have the DCT pump waiting on a speed controller the cheap one I got was junk. Should have the new one on Monday.Ismaclst wrote:Any updates?jegillis wrote:I will just get the 6000 from amazon, easy return if it doesn't work out and no duties or brokerage charges. Last time I got a $25 car part from the UK UPS charged me $130 in brokerage charges for the inconvenience of prepaying $2.50 in duty charges. I will order the stuff this week and see how it goes.
Got the new speed controller today, worked on figuring out how to use servo.write all day hopefully all will work out tomorrow
here is the code I am going to try out it compiled if anyone who knows better sees a problem with this let me know
First you need the servo libraries added to the ReefAngel libraries
This gives our servo a name (placed after the last #include)
placed this in setup to attach return pump to the low ato pin
Placed this in loop
#include <Servo.h>
Servo returnpump; // return pump control
returnpump.attach(lowATOPin); //Attaches return pump to low ato
pinMode(lowATOPin,OUTPUT);
returnpump.write(90); //value between 90 and 180
So the code works to output the correct signal from the low ato port
Running into another problem in that I need to run through my loop as close as possible to every 20ms for this to work which is not happening.
otherwise all I get is random jitters from the motor
code examples I have found have sketches that control only the motor and add a 20ms delay in the loop. Is their a way to determine how long it takes to run through the loop?
Any other ideas?
Any other ideas?
What does the servo class do?
Isn't is just a simple PWM signal?
rimai wrote:What does the servo class do?
It is a PWM signal that is sent at a 50hz instead of 490hz of a standard PWM signal
I'm using the code servo.writeMicroseconds with a value of between 1000 and 2000 now instead of just .write (value in degrees) as its easier to understand the changes.. Basically the microsecond value is the length of time on high pulse and the low pulse needs to be about 20ms consistently which is where I am getting confused as I was under the impression that the low pulse length was determined by the frequency
Looking at the Servo.h comments it looks like I can use refresh() throughout the loop to ensure that the signal is refreshed every 20ms so I may have answered my own question.
I also just found a servo library someone wrote specifically to control these esc's so I may give that a try if this doesn't work.
Ok, so I found a design flaw in the DCT pumps. It doesn't retain the speed you had when you lose power to the pump. When it starts back up it is on max speed. This is a problem for me because I restrict my drain so I can create a full siphon. Thankfully, I used the code Roberto gave me to shut off my pump when my overflow reaches a certain height. But this just creates a cycle of off and on on my pump since it is running at max speed. Has anybody heard if Jebao fixed this in a new controller? I don't want to have this happen when I'm away for an extended period of time.
Thats horrible. That would be a deal breaker for most people.
I know. I wish I had researched these before I bought mine.
Ismaclst wrote:Ok, so I found a design flaw in the DCT pumps. It doesn't retain the speed you had when you lose power to the pump. When it starts back up it is on max speed. This is a problem for me because I restrict my drain so I can create a full siphon. Thankfully, I used the code Roberto gave me to shut off my pump when my overflow reaches a certain height. But this just creates a cycle of off and on on my pump since it is running at max speed. Has anybody heard if Jebao fixed this in a new controller? I don't want to have this happen when I'm away for an extended period of time.
I contacted fish street, who I bought this from, about the problem. They are going to send me an updated controller that fixes this issue.
Did you ever get this to work correctly?jegillis wrote:So the code works to output the correct signal from the low ato port
Any other ideas?
