Skimmer float
Ask in here.
paperdesk
Skimmer float
Post by paperdesk »
I have a float switch in my skimmer overflow container. I want my skimmer to shut off when the container gets full.
Here's my code borrowed from another forum member:
ReefAngel.Relay.overide(Port8, 0);
ReefAngel.Relay.On(Port8);
I get the following verification error: class RelayClass has no member named override
What do I need to do now?
Re: Skimmer float
It's Override
paperdesk
Re: Skimmer float
Post by paperdesk »
Wow, that's embarrassing. Thanks
Ted
Re: Skimmer float
No worries :)
You can find a reference to all the functions at http://www.easte.net/RA/html
paperdesk
Re: Skimmer float
Post by paperdesk »
That site site looks like a goldmine!
paperdesk
Re: Skimmer float
Post by paperdesk »
I need a little more help. I'm not a programmer, and though I have a real interest in learning, and am learning slowly, it's going to be a while before I get even close to where I want to be. Meanwhile, I'm having a hard time figuring out how to make this skimmer float switch work. I corrected the spelling error, but get pretty much the same message.
Re: Skimmer float
Can you post your code?
Re: Skimmer float
Make sure it's Override, with a capital O and two r's. In you post you have a small 'o' and one 'r'.
I know, because I stole this code last night and got the error. :D
paperdesk
Re: Skimmer float
Post by paperdesk »
I know I'm doing something wrong, though I've tried all the suggestions! Here is my code.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardFan( Port1,780,790 );
ReefAngel.StandardHeater( Port2,780,785 );
ReefAngel.Relay.DelayedOn( Port4,8 );
ReefAngel.Relay.DelayedOn( Port5,8 );
ReefAngel.SingleATO( true,Port7,3600,5 );
ReefAngel.Relay.DelayedOn( Port8,10 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(8,0,21,0,10,70,65,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(8,0,21,0,9,40,65,9) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(8,0,21,0,8,70,65,8) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(8,0,21,0,6,40,65,6) );
ReefAngel.DCPump.SetMode( Constant,40,10 );
ReefAngel.Relay.Override(Port8);
Re: Skimmer float
Should be
ReefAngel.Relay.Override(Port8,0);
Also, it might be backwards (float switches always confuse me). If it shuts off immediately, you may need to do this:
if(!ReefAngel.HighATO.IsActive())
Re: Skimmer float
That can't be the complete code.
It's missing stuff at the end.
And that is not including the Portal function if you use it.
Also, if you check the Override function posted above, there is a second argument to that function.
It should be Override (Port8,0) and not just Override (Port8)
So, your code should be:
paperdesk
Re: Skimmer float
Post by paperdesk »
Thanks a lot! I think this did it for me though I only did a quick check so far.
