It's missing stuff at the end.
Also, if you check the Override function posted above, there is a second argument to that function.
It should be Override (Port8,0) and not just Override (Port8)
So, your code should be:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardFan( Port1,780,790 );
ReefAngel.StandardHeater( Port2,780,785 );
ReefAngel.Relay.DelayedOn( Port4,8 );
ReefAngel.Relay.DelayedOn( Port5,8 );
ReefAngel.SingleATO( true,Port7,3600,5 );
ReefAngel.Relay.DelayedOn( Port8,10 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(8,0,21,0,10,70,65,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(8,0,21,0,9,40,65,9) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(8,0,21,0,8,70,65,8) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(8,0,21,0,6,40,65,6) );
ReefAngel.DCPump.SetMode( Constant,40,10 );
ReefAngel.Relay.Override(Port8,0);
ReefAngel.Relay.On(Port8);
