Skimmer float
Skimmer float
I have a float switch in my skimmer overflow container. I want my skimmer to shut off when the container gets full.
Here's my code borrowed from another forum member:
ReefAngel.Relay.overide(Port8, 0);
ReefAngel.Relay.On(Port8);
I get the following verification error: class RelayClass has no member named override
What do I need to do now?
Re: Skimmer float
Wow, that's embarrassing. Thanks
Ted
Ted
Re: Skimmer float
That site site looks like a goldmine!
Re: Skimmer float
I need a little more help. I'm not a programmer, and though I have a real interest in learning, and am learning slowly, it's going to be a while before I get even close to where I want to be. Meanwhile, I'm having a hard time figuring out how to make this skimmer float switch work. I corrected the spelling error, but get pretty much the same message.
Re: Skimmer float
Make sure it's Override, with a capital O and two r's. In you post you have a small 'o' and one 'r'.
I know, because I stole this code last night and got the error.
Re: Skimmer float
I know I'm doing something wrong, though I've tried all the suggestions! Here is my code.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardFan( Port1,780,790 );
ReefAngel.StandardHeater( Port2,780,785 );
ReefAngel.Relay.DelayedOn( Port4,8 );
ReefAngel.Relay.DelayedOn( Port5,8 );
ReefAngel.SingleATO( true,Port7,3600,5 );
ReefAngel.Relay.DelayedOn( Port8,10 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(8,0,21,0,10,70,65,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(8,0,21,0,9,40,65,9) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(8,0,21,0,8,70,65,8) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(8,0,21,0,6,40,65,6) );
ReefAngel.DCPump.SetMode( Constant,40,10 );
ReefAngel.Relay.Override(Port8);
Re: Skimmer float
ReefAngel.Relay.Override(Port8,0);
if(!ReefAngel.HighATO.IsActive())
Re: Skimmer float
That can't be the complete code.
It's missing stuff at the end.
And that is not including the Portal function if you use it.
Also, if you check the Override function posted above, there is a second argument to that function.
It should be Override (Port8,0) and not just Override (Port8)
So, your code should be:
Re: Skimmer float
Thanks a lot! I think this did it for me though I only did a quick check so far.
