ewaldsreef
Posts: 82 Joined: Tue Oct 08, 2013 8:22 pm
Post
by ewaldsreef » Sun Feb 15, 2015 2:01 pm
Thank you so much for your time. I screwed something up lol
I was unsucessful with the code so I tryed to return to my previous code but now the lights dont workwith the timmer. Here is my current code as I have it.
byte buzzer=0;
byte overheatflag=0;
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port6Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.Relay.DelayedOn( Port4 );
overheatflag = InternalMemory.read( Overheat_Exceed_Flag );
buzzer = overheatflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetActinic( buzzer );
ReefAngel.Portal( "ewaldsreef" );
ewaldsreef
Post
by ewaldsreef » Sun Feb 15, 2015 2:19 pm
I had AI Vegas on the tank so I did not use the light ports previously. The AIs are not working right now so I went back to my old setup. I have the lights setup to run daylight at 12pm to 9pm with actinics to turn on 30 minute before and after.
Seriusly considering purchasing another setup to learn on and then add to my propigation system in the future. Also purchased and Uno to learn some basics.
Again I thank you for your help
ewaldsreef
Post
by ewaldsreef » Sun Feb 15, 2015 6:56 pm
Got everthing working perfect except the buzzer will not go on when low float is trigger in the sump. It does trigger port 8 Properly
byte buzzer=0;
boolean alert=false;
ReefAngel.StandardLights(Port2,11,30,21,30);
ReefAngel.StandardLights(Port3,12,0,21,0);
// Low Float for RO water
ReefAngel.Relay.On(Port8);
alert=false;
ReefAngel.Relay.Off(Port8);
alert=true;
// High Float for Overflow
ReefAngel.Relay.On(Port1);
alert=false;
ReefAngel.Relay.Off(Port1);
alert=true;
if (alert)
ReefAngel.PWM.SetActinic(0);
Posts: 12881 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Sun Feb 15, 2015 7:45 pm
Oh yeah....
One condition was overriding the other. Sorry.
Try this:
byte buzzer=0;
alert=false;
if ( buzzer >= 1 ) alert=true;
alert=true;
alert=true;
if (alert)
ewaldsreef
Post
by ewaldsreef » Sun Feb 15, 2015 8:37 pm
Perfect! Thank you
