New To Reef Angel - Error Uploading From Wizard
Ask in here.
nyknicks4412
Post by nyknicks4412 »
Hey everyone new to this community. Have experience programing. Was just running through the code wizard at first to get something on the device.
When i go to upload the code that has been generated for me I receive some errors that seem to indicate I am missing some libraries?
Here is the code
Port Assignment:
Port1 - Light1
Port2 - Light2
Port3 - Vortech MP10
Port4 - Heater
Port5 - Skimmer
Port6 - Reactor
Port7 - ATO
Port8 - Return
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,10,0,21,0 );
    ReefAngel.StandardLights( Port2,0,0,19,0 );
    ReefAngel.StandardHeater( Port4,780,790 );
    ReefAngel.Portal( "nyknicks4412" );
    ReefAngel.DDNS( "nyknicks4412" );
Here is the output after hitting upload
Watchdog Timer
Version Menu
Wifi Attachment
2014 Main Screen
Simple Menu
ExampleCode1.cpp: In function 'void setup()':
ExampleCode1:45: error: 'class ReefAngelClass' has no member named 'FeedingModePortsE'
ExampleCode1:48: error: 'class ReefAngelClass' has no member named 'WaterChangePortsE'
ExampleCode1:51: error: 'class ReefAngelClass' has no member named 'LightsOnPortsE'
ExampleCode1:54: error: 'class ReefAngelClass' has no member named 'OverheatShutoffPortsE'
Any help to point me in the right direction is much appreciated!
nyknicks4412
Re: New To Reef Angel - Error Uploading From Wizard
Commenting out the lines with errors allows me to compile the code...are these needed?
jegillis
Post by jegillis »
nyknicks4412 wrote:Commenting out the lines with errors allows me to compile the code...are these needed?
Did the Wizard put those lines in? I just ran the wizard and did not get them.
jegillis
Post by jegillis »
If you don't have a relay expansion you do not need them
nyknicks4412
The wizard did put them in but I am wondering if I clicked that I had a relay expansion by accident or something...I will just remove them! Thanks for the help
