What is the best way to code a port to run 3 times a week?
Re: What is the best way to code a port to run 3 times a wee
Easy enough. I'd have to test the syntax, but a switch/case statement should be able to handle that easy enough.
Honestly I think flushing the membrane though once a week should be sufficient.
Anyway, what days is it running now. You could always add a day to the now() to fast forward it a day or whatever is needed And then make it another day while skipping saturday/sunday
The Time library offers day of the week.
I think this should do it:
ReefAngel.Relay.Set(Main_RODI, ((weekday()==dowMonday || weekday()==dowWednesday || weekday()==dowFriday) && (now()+10800)<300 ));
Lee;
I was talking with Russ at Buckeye Hydro on Reef Central (http://www.reefcentral.com/forums/showt ... ?t=2369559) and he said "You should make water at least once per week. Flushing once a week or more often is a good idea too."
Right now it is running every 3 days so if I first started it on Monday then it would run Monday, Thursday. Sunday, Wednesday, Saturday and so on.
Falling back 1 day every week.
What I ultimately want to do is have it turn on port 7 to flush the membrane like Monday and Wednesday and on Friday I will have it turn on port 6 & 7 to make just RO water. It will bypass the DI resin and just flow the water out to the garden bed outside the garage.
Again this is the ultimate end goal. I would also like to have some safety statements in there that would not run either of these if my RO/DI system was triggered by my water level sensors, to make RO/DI water to refill my 20 Gallon Brute ATO Reservoir or my 20 Gallon Brut Salt Water Reservoir for Automatic water changes with in the past 48 hours.
I was going to try to attempt that on my own later, but that is what I'm going for to automate, the water change and ATO stations in terms of refilling them.
Thanks Roberto. I'll try the time library code and see how that does.
This didn't work.rimai wrote:The Time library offers day of the week.
I think this should do it:Code: Select all
I originally changed Friday to Thursday to test it that night and nothing, so I set it back to the way Roberto wrote it and although I wasn't home last night at 9pm there was no evidence there it happened.
I'm not sure why it is not working. I though t it was the double &, but that means "and".
So to me it reads as turn on the port for Main_RODI on Monday, Wednesday and Friday and 3 hours before midnight for 300 seconds (5 min).
Does anyone have a suggestion on how to do this?
I can't seem to get it to work.
Try doing several if conditions and see if it works better for you.
Do something similar for the other times.
ReefAngel.Relay.Off(Main_RODI);
if (weekday()==dowMonday && hour()==9 && minute()<5)
ReefAngel.Relay.On(Main_RODI);
Thanks. I'll try it.
hou()==9 is going to be 9am though...
So it should be the following?
if (weekday()==dowMonday && hour()==21 && minute()<5)
I tried the code and it worked fine.
I'll set up the other days later.
Thanks everyone.
Thanks everyone.
So if I wanted 9:05pm would it be...
if (weekday()==dowMonday && hour()==2105 && minute()<5)
no hour() only returns the hour not the time. You'd have to check minute >= 5 && < 10
So i tried this...
and I'm getting an "expected primary-expression before '<' token" error with the line I'm working on highlighted and the 1st "(" circled.
I'm obviously missing a comma or something, but don't know where.
if (weekday()==dowSunday && hour()==9 >= 5 && < 10 && minute()<5)
No. You need to check for day of the week, hour and minutes.
If you want minutes >= 5 and minutes < 10, it would be minute()>=5 && minute() <10
Ok. That makes sense.
Thanks.
So I've got this now and an still getting an error of expected ')' before 'minute'.
I hate trying to figure out error messages. Ugh.
I tried putting a parenthesis () around (minute()>=25 && minute()<30 and got 11 can not be used as a function.
Thanks.
if (weekday()==dowSunday && hour()==11 minute()>=25 && minute()<30 && minute()<5)
I figured out the error message. I was missing && in between the 11 and the minute, but it doesn't seem to be working.
The way I understand it with this code the Test+Light port, which is port 5 on the main relay, will run Tuesdays from 9:20pm to 9:25pm.
Nothing happened at 9:20pm.
Help???
ReefAngel.Relay.Off(Test_Light);
if (weekday()==dowTuesday && hour()==21 && minute()>=20 && minute()<25 && minute()<5)
ReefAngel.Relay.On(Test_Light);
Help???
You have an impossible condition: minute >= 20 AND minute < 5. Those 2 conditions are mutually exclusive hence nothing happens. If you remove the " &&minute()<5" clause you should get something between 21:20 and 21:24:59.
Thanks.
I'll try it later.
I'll try it later.
That did it. Thanks again.
I put this code in to turn on the solenoid for my RO/DI unit Monday, Wednesday and Friday on last Friday the 24th.
I just noticed that it only turned on on that Friday. It didn't turn on on Monday or Yesterday (Wednesday).
Is there another way to do multiple if conditions like Roberto suggested?
//Flush RO/DI Membrane 3 times a week @ 9pm.
if (weekday()==dowWednesday && hour()==21 && minute()<5)
if (weekday()==dowFriday && hour()==21 && minute()<10)
You should have just one Off at the beginning of the if statements or they will override the previous ones
Ok. I guess that is what's been happening. Thanks.
It worked perfectly.
I had a test time yesterday at 9pm, which went off fine and then it went off again tonight, as well as the other port turned on at 9:05.
Thanks for all the help.
I learned a bunch with this.
