Thank you in advance for any help.
After adding this into the code how can I turn on the buzzer (located in the actinic port)? Based off of a given channel turning on of off?
ReefAngel.CustomVar [0]=0; // Initial value. Anything other than 0 means an alert.
ReefAngel.CustomVar [7]=255; // This is a dummy to make sure the Custom Variables is always enabled in the Portal
if ( ReefAngel.IO.GetChannel(1) ) ReefAngel.CustomVar [0]=1;
if ( !ReefAngel.IO.GetChannel(2) ) ReefAngel.CustomVar [0]=2;
if ( ReefAngel.IO.GetChannel(3) ) ReefAngel.CustomVar [0]=3;
if ( !ReefAngel.IO.GetChannel(4) ) ReefAngel.CustomVar [0]=4;
if ( ReefAngel.IO.GetChannel(5) ) ReefAngel.CustomVar [0]=5;
Also I have this code on my unit and would like to replicate the same thing for a customer. Instead of using the ato port I would like to use port 0 on the IO. The purpose is to shut off port 1 when a float in the overflow is activated and set the alarm.
