Hi guys and gals. I'm a RA noob
I'm playing with the wizard as I prepare to get my RA setup in the near future. The code generator doesn't fit my application for dosing vinegar. I'm currently dosing every hour from 1pm to 9pm, for a total of 9 doses at 3 min run time each. I do this to dose during times of highest PH. The wizard only allows to dose every x minutes for y amount of time.
How would I accomplish this and then, where do I place the code once generated?
Many thanks!
Sean
How can I write custom code for BRS doser?
Re: How can I write custom code for BRS doser?
I think something like this should work. Put it in loop() and change Port1 to whatever port you're using on the relay box.
if (hour() >=13 && hour() <=21)
ReefAngel.DosingPumpRepeat( Port1,0,60,180 );
ReefAngel.Relay.Off(Port1);
Thank you so much!
Does the >=13 telling the contoller to dose at 1pm and later?
Yep. Greater than or equal to 1300 (1 PM) and less than or equal to 2100.
You're welcome!
You're welcome!
Gotcha. Thank you so much. I'm trying to also understand the method and reasoning behind it all. I did some very basic programming almost 20 years ago in high school
I just realized you said to put it in loop. Is there somewhere I need to add () in that code line you wrote?cosmith71 wrote:I think something like this should work. Put it in loop() and change Port1 to whatever port you're using on the relay box.
--ColinCode: Select all
if (hour() >=13 && hour() <=21) { ReefAngel.DosingPumpRepeat( Port1,0,60,180 ); } else { ReefAngel.Relay.Off(Port1); }
Nope. Just copy and paste it in the loop section along with your other stuff. There should be a line that reads "Put custom code here" or similar.
