PWMSmoothRampHighRes
tanked_kiwi
Re: PWMSmoothRampHighRes
Post by tanked_kiwi »
Or would it be
ReefAngel.PWM.SetChannelRaw(0, PMSmoothRampHighRes(13, 00, 22, 0, 2129, 120, 0));
Both wrong. You forgot the "Raw" on the first one, which is otherwise correct. :D
ReefAngel.PWM.SetChannelRaw(0, PWMSmoothRampHighRes(13, 00, 22, 00, 0, 52, 120, 0));
0 to 52%, from 1300 to 2200, with a 120 minute ramp up and ramp down. It should return a range of 0 to ~2130.
tanked_kiwi
Awesome thanks! As you can tell, I'm pretty new to all this coding stuff. Really appreciate the help. In future, how's the best way to find out this stuff other than asking you guys? Is it in the libraries somewhere? Have had a look but can never find anything that makes sense to me.
It's in the libraries. You just have to look at the functions and decode them as best you can. Some are better documented than others. You'll get better at it with time. :geek:
tanked_kiwi
Cool, cheers for the help anyway!
You can browse the libraries in a nice html form here:
www.easte.net/ra/html
tanked_kiwi
Thanks Inevo, that's alot easier to read.
tanked_kiwi
ok so i ran the code above today. Ramp up was good, apart from the 1st 3 or so steps you couldn't see the brightness stepping up, great! Come 9pm, I thought the tank still looked far too bright. Upon checking the controller I see all channels still at the end %. How come its not ramping down? I changed the sketch and swapped PWMSmoothRampHighRes for PWMSlopeHighRes and it seems to be working fine. Whats the difference between the 2?
I've used it for quite some time with no issues.
Post your entire code.
tanked_kiwi
////// DON'T USE MEMORY LOCATION 199 - IT IS CORRUPT!
#define Mem_B_LedOverride 100
#define Mem_B_Led100Percent 101
/////// Regular slope End%
#define Mem_B_SlopeEndCh0  259
#define Mem_B_SlopeEndCh1  262
#define Mem_B_SlopeEndCh2  265
#define Mem_B_SlopeEndCh3  268
  ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
  ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
  ReefAngel.LightsOnPortsE[0] = Port1Bit;
  InternalMemory.write(Mem_B_LedOverride, 0); //sets the controller to non masked LED mode upon boot.
  InternalMemory.write(Mem_B_Led100Percent, 0);
  ReefAngel.ActinicLights( Port2 );
  ReefAngel.ActinicLights( Port4 );
  //ReefAngel.SingleATO( true,Port5,10,1 ); <----------------------------Untested Change---------------See ATO Delay
  ////// Delay ATO after Waterchange or Feeding Mode<---------------------------------------------UNTESTED!
  static time_t wcTimer;
  if ((ReefAngel.DisplayedMenu == FEEDING_MODE) || (ReefAngel.DisplayedMenu == WATERCHANGE_MODE)) wcTimer=now();
  if (now()-wcTimer > 0 && now()-wcTimer < 600)
    ReefAngel.Relay.Off(Port5);
  else if (bitRead(ReefAngel.Relay.RelayMaskOnE[0],2))
  ////// Clear Overheat Flag after feeding or waterchange mode
  if (now()-wcTimer == 600)
    if (ReefAngel.isOverheat())
      if (ReefAngel.Params.Temp[T1_PROBE] <= 266)
        ReefAngel.OverheatClear();
  ////// Turn On LED Fan & PSU whenever any LEDs are on
  if (ReefAngel.PWM.GetChannelValue(0) > 0 || ReefAngel.PWM.GetChannelValue(1) > 0 || ReefAngel.PWM.GetChannelValue(2) > 0 || ReefAngel.PWM.GetChannelValue(3) > 0){
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port4);
  ////// ---------------Override PWM Light Channels--------------------
  // Custom Memory Location To Store Overide State for Regular Light End Values
  if (bitRead(ReefAngel.Relay.RelayMaskOnE[0],0)) {
    if (InternalMemory.read(Mem_B_LedOverride)!=1){
      InternalMemory.write(Mem_B_LedOverride, 1);
  else if (InternalMemory.read(Mem_B_LedOverride)!=0){
  // Custom Memory Location To Store Overide State for 100% Light values
  if (bitRead(ReefAngel.Relay.RelayMaskOnE[0],1)) {
    if (InternalMemory.read(Mem_B_Led100Percent)!=1){
      InternalMemory.write(Mem_B_Led100Percent, 1);
  else if (InternalMemory.read(Mem_B_Led100Percent)!=0){
  // Removes LED's from a Overridden State
  if ( InternalMemory.read(Mem_B_LedOverride) == 0){
    if (InternalMemory.read(Mem_B_Led100Percent) == 0)
      ////////PWMSlopeHighRes Working
       ReefAngel.PWM.SetChannelRaw( 0, PWMSlopeHighRes(13,00,22,00,0,28,120,0)); //Set Channel 0 to PWMSlope using internal memory settings for Channel 0
       ReefAngel.PWM.SetChannelRaw( 1, PWMSlopeHighRes(13,00,22,00,0,23,120,0)); //Set Channel 1 to PWMSlope using internal memory settings for Channel 1
       ReefAngel.PWM.SetChannelRaw( 2, PWMSlopeHighRes(13,00,22,00,0,28,120,0)); //Set Channel 2 to PWMSlope using internal memory settings for Channel 2
       ReefAngel.PWM.SetChannelRaw( 3, PWMSlopeHighRes(13,00,22,00,0,32,120,0)); //Set Channel 3 to PWMSlope using internal memory settings for Channel 3
       ReefAngel.PWM.SetChannelRaw( 0, PWMSmoothRampHighRes(13,00,22,00,0,28,120,0)); //Set Channel 0 to PWMSlope using internal memory settings for Channel 0
       ReefAngel.PWM.SetChannelRaw( 1, PWMSmoothRampHighRes(13,00,22,00,0,23,120,0)); //Set Channel 1 to PWMSlope using internal memory settings for Channel 1
       ReefAngel.PWM.SetChannelRaw( 2, PWMSmoothRampHighRes(13,00,22,00,0,28,120,0)); //Set Channel 2 to PWMSlope using internal memory settings for Channel 2
       ReefAngel.PWM.SetChannelRaw( 3, PWMSmoothRampHighRes(13,00,22,00,0,32,120,0)); //Set Channel 3 to PWMSlope using internal memory settings for Channel 3
  // Override LED's to End% Intensity for each Channel
  if (( InternalMemory.read(Mem_B_LedOverride) == 1) && (Mem_B_Led100Percent == 0 ))
    ReefAngel.PWM.SetChannel( 0, Mem_B_SlopeEndCh0 ); //Set channel 0 to channel 0 end%
    ReefAngel.PWM.SetChannel( 1, Mem_B_SlopeEndCh1 ); //Set channel 1 to channel 1 end%
    ReefAngel.PWM.SetChannel( 2, Mem_B_SlopeEndCh2 ); //Set channel 2 to channel 2 end%
    ReefAngel.PWM.SetChannel( 3, Mem_B_SlopeEndCh3 ); //Set channel 3 to channel 3 end%
  // Override LED's to 100% Intensity for each Channel
  if (Mem_B_Led100Percent == 1 )
    ReefAngel.PWM.SetChannel( 0, 100 ); //Set channel 0 to channel 0 100%
    ReefAngel.PWM.SetChannel( 1, 100 ); //Set channel 1 to channel 1 100%
    ReefAngel.PWM.SetChannel( 2, 100 ); //Set channel 2 to channel 2 100%
    ReefAngel.PWM.SetChannel( 3, 100 ); //Set channel 3 to channel 3 100%
  ////// Prevent Filling ATO past float switch even if overridden
  if (bitRead(ReefAngel.Relay.RelayMaskOn,4)){
    if (!ReefAngel.LowATO.IsActive()){
      bitClear(ReefAngel.Relay.RelayMaskOn,4);
  ////// Override Float Switch for Waterchange Drum
  if (bitRead(ReefAngel.Relay.RelayMaskOnE[0],3)) {
    ReefAngel.Relay.On(Port1);
  else {
    ReefAngel.Relay.Off(Port1);
  /////// Refill (Salt Water) after water change to ATO height Relay Port 1
  if (ReefAngel.DisplayedMenu != WATERCHANGE_MODE){
    if (bitRead(ReefAngel.Relay.RelayMaskOn,0)){
        bitClear(ReefAngel.Relay.RelayMaskOn,0);
  ReefAngel.Portal( "tanked_kiwi" );
I take that back. I'm not using SmoothRamp. I'll try it and report back.
So I've had this running for several days. It's unpredictable. Some days the whites would dim really fast at the end of the cycle. Last night they were at about half brightness near the end and then instantly 0. Not sure why.
I'm going back to PWMSlopeHighRes instead.
AlanM
Post by AlanM »
cosmith71 wrote:So I've had this running for several days. It's unpredictable. Some days the whites would dim really fast at the end of the cycle. Last night they were at about half brightness near the end and then instantly 0. Not sure why.
Colin, what code were you using on the PWMSmoothRampHighRes calls? Can you post up a snippet? I have a unit that I can run tests on and would like to try to see what's going on with it.
Something like this:
    ReefAngel.PWM.SetChannelRaw(0,PWMSmoothRampHighRes(9,30,22,30,0,70,60,0));
AlanM
Post by AlanM »
OK. So you have that in your loop without any other time-based if statements around it that might be changing when the profile starts or stops?
Yup.
What shape is SmoothRamp? Is it a parabolic beginning and end?
AlanM
Post by AlanM »
cosmith71 wrote:Yup.
Actually, it's intended to be flat in the middle with a half-period of a Cosine function at the beginning and the end which is shifted up and divided by 2 so that it goes from 0 to 1 instead of from -1 to 1. The intent is to have a tail at the beginning of the day and the end of the day rather than an immediate slope upwards in the morning.
I did it that way because I can really see the difference between 1 and 5 in dimming levels when my meanwell LDDs are really dim, but it's impossible to see the difference between 2001 and 2005 in the middle of the ramp.
I actually like the sigmoid ones better than smoothramp because the tails are longer. That's what I run on my lights.
I'm using internal memory for my lights final intensities and start and end times, but I do:
  ReefAngel.PWM.SIXTEENChannelPWMSigmoid(2,0,InternalMemory.PWMSlopeEnd0_read()); // RB channel, startpwm, endpwm, offsets
Where my Royal Blue channel goes from 0 to the slope end value on 16 channel dimming module channel 2.
AlanM
Post by AlanM »
Colin,
I described SmoothRamp and Sigmoid with graphs here (at least what they're supposed to do):
http://forum.reefangel.com/viewtopic.php?f=7&t=4812
And you can see what it looks like actually running on my lights here:
http://forum.reefangel.com/status/chart ... er=scpwme2
I'm going to run it again tonight and pay closer attention to see what it does. I'll look at the graph, too.
tanked_kiwi
Thank you both for looking into this. AlanM, I have the same issue you do with the meanwell LDD drivers, that is the whole reason I went looking at the high res and different slopes. Will try sigmoid and see how I get on.
Here's the chart from last night. The lights should start dimming at 2100. Ignore the dips earlier. That was cloud code that I disabled just to make sure it wasn't interfering.
http://forum.reefangel.com/status/chart ... lter=pwme1
Reef Angel Web Chart PWME1.jpg (17.54 KiB) Viewed 3400 times
Interestingly, the blues on channel 0 seem to be working correctly.
http://forum.reefangel.com/status/chart ... lter=pwme0
Reef Angel Web Chart PWME0.jpg (15.99 KiB) Viewed 3400 times
Here's the lighting control code:
// Cloud/lightning lighting control
    FireInTheHole=false;
    ReefAngel.PWM.SetChannelRaw(0,PWMSmoothRampHighRes(9,30,22,30,0,InternalMemory.read(Mem_B_SlopeEndBlue),60,0));
    DaylightPWMValue=PWMSmoothRampHighRes(10,30,22,0,0,InternalMemory.read(Mem_B_SlopeEndWhite),60,0);
    //if (!powerOutage) CheckCloud();
    if (!FireInTheHole) ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
I'm going to change that mess to this just to make sure.
ReefAngel.PWM.SetChannelRaw(1,PWMSmoothRampHighRes(10,30,22,0,0,75,60,0));
