URGENT - Error uploading Code - Blank Screen
rrodriguess
Post by rrodriguess »
Hi guys
I may have a big problem on my hands. I will try to be as clear as possible despite the language barrier.
Last night I came home and my reefangel was working fine. Then I tryed to upload a code through bluetooth as I normally do. I got this error:
avrdude: Recv: U [55]
avrdude: Recv: n [6e]
avrdude: Recv: k [6b]
avrdude: Recv: o [6f]
avrdude: Recv: w [77]
avrdude: Recv:   [20]
avrdude: Recv: C [43]
avrdude: Recv: m [6d]
avrdude: Recv: a [61]
avrdude: Recv: d [64]
avrdude: Recv: . [0d]
avrdude: Recv: . [0a]
avrdude: Recv: R [52]
avrdude: Recv: e [65]
avrdude: Recv: f [66]
avrdude: Recv: A [41]
avrdude: Recv: g [67]
avrdude: Recv: l [6c]
avrdude: Recv: > [3e]
avrdude: Recv:   [20]
avrdude: Recv:   [20]
avrdude: Recv: Q [51]
avrdude: Recv:   [20]
avrdude: Recv: u [75]
avrdude: Recv: i [69]
avrdude: Recv: t [74]
avrdude: Recv:   [20]
avrdude: Recv: & [26]
avrdude: Recv:   [20]
avrdude: Recv: j [6a]
avrdude: Recv: p [70]
avrdude: Recv:   [20]
avrdude: Recv:   [20]
avrdude: Recv: s [73]
avrdude: Recv: r [72]
avrdude: Recv:   [20]
avrdude: Recv: . [1b]
avrdude: Recv: . [10]
avrdude: Recv: . [00]
avrdude: Recv: . [02]
avrdude: Recv: . [0e]
avrdude: Recv: . [13]
avrdude: Recv: . [14] "
and
"avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_command(): failed miserably to execute command 0x1d
avrdude: stk500v2_cmd(): failed to send command"
In th first we can se a vertical message written:
"Unknown command. Reef Angel unknow Command. Quit & junp to user pgm" (what hell?)
Tryed again, and again. Same thing. Turned off my computer bluetooth and turned back on. Nothing. Reboot my computer and... nothing.. same error!!
A few minutes later I decided to take a look at the controller itself. Its screen was gone.. I mean all I got was a blank screen.
Thought to myself: "Ok.. no reason to get worried.. just reboot it by talking off the wall".
Nothing happened... I get the same blank screen and a solid green led.
Tryed to use the TTL cable to upload a code. When I connect the USB cable on my computer I get flashing red led for a few moments and then a solid green led.
Using the TTL cable, the same error occurs "failed miserably to execute...".
By reading some posts with the same error, I double checked:
Water Damage
TTL cable not connect properly
Correct Board
Corret Serial Port
Well.. after 2 hours trying to make it work... I have to say.. I am quite worried. Even If I have to buy a new unit, I am in south america, and can't have the luxury to wait a month to get the aquarium running again.
Can someone help me please?
If necessary I can post photos and videos showing what is going on.
Tks
Rafa
Re: URGENT - Error uploading Code - Blank Screen
Try loading a very simple code like this:
Can you upload this code?
rrodriguess
Surprisingly I can upload this simple code!
Immediately tryed my oold code.. and got the same error.
Any thoughts?
It has to be something in your code that is causing that behavior.
The controller has a bootloader that has a special diagnostic mode when !!! is sent in sequence.
I think your code is causing the bootloader to enter this diagnostic mode somehow.
rrodriguess
Worked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
removed my last alteration:
"if(feedMessage==false && ReefAngel.DisplayedMenu == RETURN_MAIN_MODE){
SENDEMAIL=true;
EMAILMESSAGE="Feeding+Mode:+Ended";
feedMessage=true;
Maybe I cannot use if(feedMessage==false && ReefAngel.DisplayedMenu == RETURN_MAIN_MODE) ?
Tks Roberto!!!!!
