I have recently installed my RA with a wifi attachment and 2 jebao cables connected to both of the PWM connections on my controller.
I am able to do some basic functionality through the portal and internal memory to control my pumps.
I have several questions about the coding and control of the pumps. I've been searching and have not really found and concise information about the pumps/setting and programming.
Is there an explanation somewhere about what the actual pump modes are and what their behavior is?
Do I need to adjust the light schedule and dimming settings in the memory to make sure the PWM light channels don't effect the DC pump operation?
Is there somewhere I can go with more in depth documentation?
DC Pump PWM coding and modes
120g High Mixed Reef
60g Cube Mixed Reef
60g Cube Mixed Reef
Re: DC Pump PWM coding and modes
Thank you, but I was actually looking for something to explain the actual pattern and what they are simulating.
60g Cube Mixed Reef
60g Cube Mixed Reef
