Cloud and Lightning Code for Dimming Expansion
PostPosted: Sun Jun 21, 2015 12:16 pm
Here it is. See this thread for general instructions.
Up in the globals section (somewhere before void setup()) add this line:
int DaylightPWMValue=0;        // For cloud code
In your loop, you need to find whatever function is controlling your white lights and set it to the DaylightPWMValue variable. For example, I use something like this:
DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,85,60,0);
 CheckCloud();
 ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
Which is a high res (12 bit) slope that starts at 1030, runs until 2200, starts at 0%, ends at 85%, and takes 60 minutes to ramp up and down. If this part confuses you, post your lighting control code and I can help you with it.
Essentially what this section does is set the baseline lighting for when there is no cloud going on. This is your everyday lighting routine.
At the very end of your code, after the final }, paste in all this stuff.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(12,00)
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Mega2,Mega,Mega};
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=4095;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      else x=35;
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
As written, this flashes channel 1 on the standard 6 channel Dimming Expansion Module.
This version does not write times to the screen. That option does not work well with the new screen functions. It will write the times into the custom variables so you can see them on the portal.
What's new:
Lightning generator broken out into its own function strike() since it's somewhat longer and more complicated now for the dimming module.
Everything is in 12 bit hi-res now. This pretty much breaks "Slow" mode. I should probably just depreciate it.
As always, ask away with any questions or comments.
PostPosted: Sun Jun 21, 2015 12:17 pm
Reserved for future use.
PostPosted: Sun Jun 21, 2015 12:31 pm
Awesome Colin.
I just need to get some time to mod my lights for the control.
PostPosted: Mon Jun 22, 2015 8:49 am
I still want slow mode :)
PostPosted: Mon Jun 22, 2015 9:37 pm
Are you able to use this along with the sunlocation code?
PostPosted: Tue Jun 23, 2015 2:44 am
Probably not without modification.
PostPosted: Tue Jun 23, 2015 2:49 am
lnevo wrote:I still want slow mode :)
Fixed, just for you. :D
PostPosted: Tue Jun 23, 2015 7:53 am
I think Steve would have needed it too, he just doesn't know it yet.
PostPosted: Tue Jun 23, 2015 8:02 am
OK. Thanks????
PostPosted: Tue Jun 23, 2015 3:22 pm
Your hacking blacboxes yes?
Next
Return to How do I code ...
