Cloud and Lightning Code for Dimming Expansion
Re: Cloud and Lightning Code for Dimming Expansion
Not yet. Still trying to set up the 90 gallon.
Colin;
How would you write this if you wanted to control 2 channels.
I have my white (Daylights) set up on Channel 0 and 2.
Would it be like this...
or this
int DaylightPWMValue=0; // For cloud code
int DaylightPWMValue=2; // For cloud code
int DaylightPWMValue=0,2; // For cloud code
No, it'll take a little more than that. It'll take a modification to the strike() subroutine to add the extra channel. I'll see if I can come up with something tonight after work.
Thanks.
Also the 2 white channels are offset by 30 min so would the strikes be on sync or not?
My lighting is setup like this.
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,12,30,21,0 );
//East to West Sunrise/Sunset Dimming
ReefAngel.PWM.SetChannel( 0, PWMSlope(12,30,20,30,0,100,60,0) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,0,100,60,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,21,0,0,100,60,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(12,30,22,0,0,100,60,0) );
The first part just turns the relay ports on and off, but the 2nd part is the east to west dimming.
Are you using fast drivers?
I think they are slow drivers that is why Lee wanted the slow mode and said
I'm using the Evergrow Dimmable Full Spectrum D2120lnevo wrote:I think Steve would have needed it too, he just doesn't know it yet.
That complicates things a bit more since Slow is handled differently. Give me a little more time to write it up.
I have it worked out in my head, just have a 12 hour work shift today.
That's great.
Hope your shift is not to difficult.
No rush.
Whenever you can get it together.
No rush.
OK. I wasn't able to test, but I think this should do it.
Up in globals:
Replace your lighting code in loop() with this:
And here's the stuff at the end.
Let me know how it works. This code should also work for fast drivers on channels 0 and 2 for the other modes.
Up in globals:
int DaylightPWMValue0=0; // For cloud code, channel 0
int DaylightPWMValue2=0; // For cloud code, chennel 2
ReefAngel.PWM.SetChannel( 1, PWMSlopeHighRes(12,0,21,30,0,100,60,0) ); // Schedule for blues
ReefAngel.PWM.SetChannel( 3, PWMSlopeHighRes(12,30,22,0,0,100,60,0) );
DaylightPWMValue0=PWMSlopeHighRes(12,30,20,30,0,100,60,0); // Default for whites
DaylightPWMValue2=PWMSlopeHighRes(13,0,21,0,0,100,60,0);
CheckCloud(); // Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0); // Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2); // lightning if it's time.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(12,00)
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega2,Mega,Mega};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue0/40.95,0,180)*40.95;
DaylightPWMValue2=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue2/40.95,0,180)*40.95;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue0=4095;
DaylightPWMValue2=4095;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
else x=75;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. This is channel 0.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
Wire.write(0x8+(4*2)); // 0x8 is channel 0, 0x12 is channel 1, etc. This is channel 2.
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(0); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
newdata=ReefAngel.PWM.GetChannelValueRaw(2); // Use the channel number you're flashing here
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
Thanks Colin.
I'll try to test it tonight.
If not definitely over the weekend.
There's some errors in the code.
I guess this is the line that does the cloud but you want to do it for both and this one is never declared so I'm guessing
Colin, I need a way to call the cloud/lightning routine on demand. What you got for me? I haven't read through the code enough to comprehend that yet.
Ooops, missed that part. It's fixed now.
Give me a bit on the on-demand. I have an idea.
I actually added two more variables for my actinics and using another function to do an override (for presets 60/40 80/20, etc.)
I want one of those relays to trigger a cloud/lightning and then I think my life will be complete
I got the a 'DaylightPWMValue' error was not declared in this scope on DaylightPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
Also when you say the last stuff goes "At the very end, outside of loop() and past everything else add this.", is that after the...
Ooops, fixed.
Put it at the very end of everything. You technically could put it before void DrawCustomGraph() but it's easier if you just put it at the very end of the sketch.
On demand cloud. It's a little dirty, but it works.
The difference is this section here.
Change to whichever port you want to use as a trigger. You can use a port on a non-existent relay box. If that port is turned on, the cloud will start. There has to be a chance of clouds for that day and it will use whatever lightning type is next up (if you're using multiple types).
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
if (ReefAngel.Relay.Status(Port6)) // Change this to whatever port you want to use as a trigger.
cloudstart = NumMins(hour(), minute());
ReefAngel.Relay.Override(Port6,2); // Here, too.
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
// Flash on
int newdata=4095;
cstart*=60;
cend*=60;
Very cool Colin.
I haven't had a chance to try the cloud and lightning code yet because I had some issue with my tank that I've been trying to work out this weekend, but I can't wait to.
The on demand feature is very awesome.
Thanks Colin. The only thing dirty is that it depends on 100% chance of clouds. If it's not a cloudy day I won't be able to trigger. But this is good... better than anything else I've seen. I'm looking forward to testing it!
Ok, so here's my report back. I had a few issues and some warnings just in case other's decide to follow suit. I know of only one person impacted though (AlanM...)
I realized just now you're writing all these portal variables.. well I so happen to have one that if I put my alk reading in, it will calculate how much alk and start dosing it. Now, I caught this quickly enough, but I probably dosed a 150ml or so into the tank. Don't feel bad, it's essentially a softie tank, all my SPS died a while ago, just hope the stylo and spongodes that made it through can handle it. Water change is happening this morning regardless.
Now back to the code. I need to do some more testing, which I'll take care of shortly, but my lights essentially do nothing (I didn't see them dim, but I wasn't watching the controller either...) Then the lights go off and I think the lightning kicks in shortly after. There were a few effects that were cool, some that were going on/off too fast. Part of the problem is the RA turns my ports off if the dimming is less than 1%. I'm going to try the effect with the bottom at 2% and let's see this way the relay's not in the way. I aslo did some tweaks because in a cloud you're only going to get one lightning sequence at 5 seconds. I upped it to 10 and made it happen every minute after a 3rd of the way through. Anyway a little ways after that, my whites came back on in sequence which was perfect (thought they went off simultaneously).
I'm going to upload my fixes and tweaks and try again once my lighting comes back on. Will report back soon.
The hardest part is getting it to work on other folks hardware, since I can't test every configuration. I basically lost interest in the slow mode after getting the fast drivers.
Sorry about the alk. Hope it doesn't hurt anything.
Ok. everything is actually working good... I'm happy with the longer lightning strike. I also broke the Slow stuff into a separate function so I could call it separately while a different relay is on. So I have one state that triggers the cloud and another state that triggers just lightning every minute I then enhanced the slow strike a bit by separating out my two channels so there's a chance for both to light and a slight chance for left and right separately. The effect is pretty cool. I also added a HighRes ReversePWMSlope, not that it was needed, but since we're dealing with a HighRes variable it was easy enough to do. I separated out the Drawing functions to another function so I had to make the variables global. If I can make this more OO then those would go away, I'm hoping they annoy me enough to do the work.
Anyway, here's what I left off with. I've been toying with increasing my actinic channel during a cloud or lightning, I left that commented out for now.
void CheckCloud()
// Minimum number of minutes for cloud duration. Don't use min duration of less than 6
#define Min_Cloud_Duration 10
#define Max_Cloud_Duration 20
#define Max_Clouds_per_Day 4
#define End_Cloud_Before NumMins(23,00)
byte LightningModes[] = {Slow};
#else
#endif
if (cloudchance)
if (cloudchance)
if (ReefAngel.Relay.isMaskOn(LED_STORM)) // Change this to whatever port you want to use as a trigger.
ReefAngel.Relay.Auto(LED_STORM); // Here, too.
// Increase Blue channel first for better effect and to compensate for drop in Whites
//ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
//ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
if (lightningchance && (NumMins(hour(),minute())>=(cloudstart+(cloudduration/3))) && second()<10)
SlowStrike();
break;
default:
break;
cloudindex++;
// Cloud ON option - Clouds every minute
if (ReefAngel.Relay.isMaskOff(LED_STORM) && now()%60<10)
SlowStrike();
void SlowStrike()
int r = random(100);
if (r<20) lightningstatus=1;
// Let's separate left and right both.
if (r<13 ) {
} else if (r<16) {
DaylightPWMValue2=100;
DaylightPWMValue0=100;
delay(1);
void DrawClouds(int x, int y)
ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
int x=0;
else x=17;
ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
//ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
//ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
//ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
int x=0;
if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
else x=57;
ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
//ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
else x=75;
ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
//ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
// Flash on
int newdata=4095;
cstart*=60;
cend*=60;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
cstart*=60;
cend*=60;
As far as the alk, don't worry, I think I'll be fine. At least my pH alarm caught it. I spiked to 8.6. I would have gotten to it sooner too if I wasn't also testing new code since I thought the alert was from a few of the power cycles. Glad I took a closer look!
God I so want to get this working, but I need to get my light straightened out and working properly first.
At first my channel 3 (the 2nd Daylight) wasn't dimming so I opened the light up over the weekend and some of the wire slipped out of the connection so I re-did everything and it just made it worse.
Now none of the channels dim and my moonlight are not functioning properly. Staying full on day and night.
This code does not seem to be working or I have a bad connection somewhere.
I need to get some time and un-mod the lights, get the moonlights working again and start from scratch,
if ( hour()>=13 && hour()<21 )
ReefAngel.PWM.SetChannel( 5, 0 );
ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
Lee were you testing your lights around 12:20 today?
I took a look at your Reeftronics specs to see how your lights dim and there was a spike at 12:20pm
It looks funny.
It looks funny.
What your seeing is my moonlights. They do a parabola from Moon rise to moon set and they go from 100-0 and 0-100 to fill in the 0-10% that my regular lights can't do. The spikes you see are morning and night
Overall though I've been testing my lights all day. I now have a bunch of presets I can use as well as on-demand clouds on-demand lightning
I've been considering breaking out my lights to left and right channels (they're 1 channel for both sides right now) to enchance the lightning effect, similar to what you did. I have a week off coming up so I just might do that.lnevo wrote:Ok. everything is actually working good... I'm happy with the longer lightning strike. I also broke the Slow stuff into a separate function so I could call it separately while a different relay is on. So I have one state that triggers the cloud and another state that triggers just lightning every minute I then enhanced the slow strike a bit by separating out my two channels so there's a chance for both to light and a slight chance for left and right separately. The effect is pretty cool. I also added a HighRes ReversePWMSlope, not that it was needed, but since we're dealing with a HighRes variable it was easy enough to do. I separated out the Drawing functions to another function so I had to make the variables global. If I can make this more OO then those would go away, I'm hoping they annoy me enough to do the work.
