Cloud and Lightning Code for Dimming Expansion
Re: Cloud and Lightning Code for Dimming Expansion
The music sucks, but it looks nice.
It was stock. Needed something that matched the mood. :)
2 strange requests if it's not to much trouble.
1st the ability to add a thunder clap SFX.
2nd possible lightning strike at night when the lights are off or at 0.
You can tell me no and I won't be offended.
I've tested with blues off. I don't see why it wouldn't work with all lights off. Yes, I'm sorely missing sound effects. Where has that code gone...
For sound effects, just have a neighborhood kid stand by the tank and say 'pew pew pew' when the lightning goes off. :D
Stole the ReversePWMSlopeHighRes function and split my whites into left and right channels. Here's the result.
http://www.youtube.com/watch?v=ZoMFDrJqGgg
It looks awesome Colin. I think I need to do something where I do more frequent but shorter clouds. I also think I need to get my blue channel involved as well. I wish I could swap my drivers for something better. Love my lights though and now that I have some effects, it's awesome. Btw, I have to also say that having a set of presets is awesome. I can now in one click select any ration whites to blues. The cool thing is I run that before I run the cloud function, so I can see the cloud/lightning or lightning effect on any temp combo.
Here's what I'm currently getting ready to test. I've added the blues, but not sure my function will work. I'm also brightning the blues when the lightning strikes because my whites need to stay on for the cloud duration. I lowered that from 10 seconds to 8 and made it recur every 45 seconds instead of every 60. We'll see how it does.
void CheckCloud()
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  byte LightningModes[] = {Slow};
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
        // if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
        if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOff(LED_STORM))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(LED_STORM);    // Here, too.
    //is it time for cloud yet?
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
      DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        if (lightningchance && second()%40<8)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOn(LED_STORM) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(100);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left and right both.
      if (r<14) {
        DaylightPWMValue0=4095;
        DaylightPWMValue2=4095;
        ActinicPWMValue1=4095;
        ActinicPWMValue3=4095;
      } else if (r<17) {
        DaylightPWMValue0=100;
        DaylightPWMValue2=100;
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      //ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      //ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    //ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      //ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        //ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 2.
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(2);   // Use the channel number you're flashing here
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
Rodasphoto
Post by Rodasphoto »
lnevo wrote:As far as the alk, don't worry, I think I'll be fine. At least my pH alarm caught it. I spiked to 8.6. I would have gotten to it sooner too if I wasn't also testing new code since I thought the alert was from a few of the power cycles. Glad I took a closer look!
Sacohen wrote:2 strange requests if it's not to much trouble.
Adding thunder sfx would be an awesome addition to the lightning. Maybe adding some rain as well with a small pump from the overflow to some rain shower heads. Like this one
https://www.amazon.com/gp/aw/d/B000PUHV ... OXUXL&vs=1
Sent from my Nexus 6 using Tapatalk
MDB1029
Post by MDB1029 »
Not sure if this is the right thing to do or not.
This is my loop code
    ReefAngel.StandardHeater( Port2 );
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardLights( Port7,18,0,10,0 );
    ReefAngel.DayLights( Box1_Port1 );
    ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Box1_Port1 ) );
    ReefAngel.Relay.Set(Port8, now()%21600<10800);
Where do i put this:
    DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,85,60,0);
     CheckCloud();
     ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
in place of ReefAngel.PWM.DaylightPWMSlope();
And should the last part go in here?
    [color=#BF0000]XXXXXX[/color]
I am adding the dimming expansion if the post office can ever manage to get it delivered. Does this distinguish which channel on the dimming expansion i am using? I figured i would use channel 0 for my whites and 1 for my blues but not sure how this is telling which to do what? Am i missing something?
MDB1029
Post by MDB1029 »
Also i second being able to have some lightning at night.
I searched all over the forums and couldn't find the code for the SFX.
MDB1029 wrote:Not sure if this is the right thing to do or not.
     CheckCloud();
Yes, but change it to ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue); if your whites are on channel 0.
Nope, past that. Put it at the very end, past everything else.
I knew about The Talking Reef thread, but I seem to remember another one that dealt with thunder specifically.
I'm still working our some issues with my dimming, before I add the lighting.
MDB1029
Post by MDB1029 »
     CheckCloud();
So after this?
    ReefAngel.Portal( "MDB1029" );
    ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
Yes.
MDB1029
Post by MDB1029 »
So I added this and my blues stopped working.
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 7
    #define Min_Clouds_per_Day 1
    #define Max_Clouds_per_Day 2
    #define Start_Cloud_After NumMins(12,00)
      // Add Random Lightning modes
      byte LightningModes[] = {Mega2,Mega,Mega};
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
      static byte lightningMode=0;
    #else
    #endif
          if (cloudchance)
      if (cloudchance)
          case Calm:
            break;
          case Mega:
              // Send the trigger
              Strike();
            break;
          case Mega2:
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
                DaylightPWMValue=4095;
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          int x=0;
          else x=17;
          else x=35;
          int x=0;
          else x=57;
          else x=75;
    void Strike()
        // Flash on
        int newdata=4095;
        Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
        newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
      cstart*=60;
      cend*=60;
Any suggestions? Both white and blue were working before adding this code. White channel 0 Blue channel 1. I tried to change to the highres slope for the blue channel as well, Did I not do it correctly? Also can you look at the daylight setting and tell me if i changed it to channel 0 correctly?
MDB1029
Post by MDB1029 »
So on the portal it was showing channel 1 at 204% and the voltage being put out at the dimming expansion was 0.35v when the white channel was at 1.6v. I looked at the diodes themselves and they were on just extremely low and couldn't tell without seeing them. I have them set at 30% through the app right now.
On another note, how can i tell if the cloud and lightning is working?
Post all of your code.
MDB1029
Post by MDB1029 »
Sorry i thought i had it all posted but i guess not
    int DaylightPWMValue=0;        // For cloud code
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port4 );
        DaylightPWMValue=PWMSlopeHighRes(10,0,20,0,0,30,60,0);
     CheckCloud();
    ReefAngel.PWM.SetChannel(1,PWMSlopeHighRes(9,30,20,30,5,30,30,0));  // Blues from 0930 to 2230 on a slope
    ReefAngel.StandardLights(Port7,18,0,10,0);  // Fuge light from 1800 to 1000
      void CheckCloud()
    #else
    #endif
          if (cloudchance)
      if (cloudchance)
          case Calm:
            break;
          case Mega:
              // Send the trigger
              Strike();
            break;
          case Mega2:
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          int x=0;
          else x=17;
          else x=35;
          int x=0;
          else x=57;
          else x=75;
    void Strike()
        // Flash on
        int newdata=4095;
      cstart*=60;
      cend*=60;
Ah. Change this:
To this:
    ReefAngel.PWM.SetChannelRaw(1,PWMSlopeHighRes(9,30,20,30,5,30,30,0));  // Blues from 0930 to 2230 on a slope
Check custom variables 3 and 4 for the time of the next cloud (either using the app or the portal). 3 is the hour, and 4 is the minute of the next cloud. You can either wait for that time, or change the current time on the controller to the cloud time to make it happen now. Just make sure to change it back. Helps to do a reset afterwards, too.
MDB1029
Post by MDB1029 »
Thank you. Will make the changes now.
MDB1029
Post by MDB1029 »
The dimming is working perfectly now. I am sure I will mess somthing up forcing a cloud event. I saw it yesterday for a moment and it looked like the Blue on channel 1 was flashing. The only part i changed was what is in the code 2 posts up.
Only channel 0 should flash. Are you sure the blues are flashing?
MDB1029
Post by MDB1029 »
cosmith71 wrote:Only channel 0 should flash. Are you sure the blues are flashing?
Between the flashes it is blue but only looks like the blue is flashing and the white is not present.
Can you do a video?
MDB1029
Post by MDB1029 »
I can try if i am home during the next cloud. I may also disconnect the blue channel dimming wire and see what the result is.
The blue should stay the same. The white should slowly dim with flashes of varying length and intensity, like the videos above.
