Cloud and Lightning Code for Dimming Expansion
Re: Cloud and Lightning Code for Dimming Expansion
Also i second being able to have some lightning at night.
I searched all over the forums and couldn't find the code for the SFX.
Yes, but change it to ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue); if your whites are on channel 0.MDB1029 wrote:Not sure if this is the right thing to do or not.
This is my loop codeWhere do i put this:Code: Select all
void loop() { ReefAngel.StandardHeater( Port2 ); if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); }; if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); }; ReefAngel.SingleATOLow( Port5 ); ReefAngel.StandardLights( Port7,18,0,10,0 ); ReefAngel.DayLights( Box1_Port1 ); ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Box1_Port1 ) ); ReefAngel.PWM.DaylightPWMSlope(); ReefAngel.PWM.ActinicPWMSlope(); ReefAngel.Relay.Set(Port8, now()%21600<10800);
in place of ReefAngel.PWM.DaylightPWMSlope();Code: Select all
DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,85,60,0); CheckCloud(); ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
Nope, past that. Put it at the very end, past everything else.And should the last part go in here?Code: Select all
////// Place your custom code below here [color=#BF0000]XXXXXX[/color] ////// Place your custom code above here // This should always be the last line
I knew about The Talking Reef thread, but I seem to remember another one that dealt with thunder specifically.
I'm still working our some issues with my dimming, before I add the lighting.
So after this?cosmith71 wrote:Yes, but change it to ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue); if your whites are on channel 0.MDB1029 wrote:Not sure if this is the right thing to do or not.
ReefAngel.Portal( "MDB1029" );
ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
So I added this and my blues stopped working.
Any suggestions? Both white and blue were working before adding this code. White channel 0 Blue channel 1. I tried to change to the highres slope for the blue channel as well, Did I not do it correctly? Also can you look at the daylight setting and tell me if i changed it to channel 0 correctly?
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(12,00)
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega2,Mega,Mega};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
else x=75;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(1); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
So on the portal it was showing channel 1 at 204% and the voltage being put out at the dimming expansion was 0.35v when the white channel was at 1.6v. I looked at the diodes themselves and they were on just extremely low and couldn't tell without seeing them. I have them set at 30% through the app right now.
On another note, how can i tell if the cloud and lightning is working?
Post all of your code.
Sorry i thought i had it all posted but i guess not
int DaylightPWMValue=0; // For cloud code
ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
DaylightPWMValue=PWMSlopeHighRes(10,0,20,0,0,30,60,0);
CheckCloud();
ReefAngel.PWM.SetChannel(1,PWMSlopeHighRes(9,30,20,30,5,30,30,0)); // Blues from 0930 to 2230 on a slope
ReefAngel.StandardLights(Port7,18,0,10,0); // Fuge light from 1800 to 1000
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
// Flash on
int newdata=4095;
cstart*=60;
cend*=60;
Ah. Change this:
To this:
Check custom variables 3 and 4 for the time of the next cloud (either using the app or the portal). 3 is the hour, and 4 is the minute of the next cloud. You can either wait for that time, or change the current time on the controller to the cloud time to make it happen now. Just make sure to change it back. Helps to do a reset afterwards, too.
ReefAngel.PWM.SetChannelRaw(1,PWMSlopeHighRes(9,30,20,30,5,30,30,0)); // Blues from 0930 to 2230 on a slope
Thank you. Will make the changes now.
The dimming is working perfectly now. I am sure I will mess somthing up forcing a cloud event. I saw it yesterday for a moment and it looked like the Blue on channel 1 was flashing. The only part i changed was what is in the code 2 posts up.
Only channel 0 should flash. Are you sure the blues are flashing?
Between the flashes it is blue but only looks like the blue is flashing and the white is not present.cosmith71 wrote:Only channel 0 should flash. Are you sure the blues are flashing?
Can you do a video?
I can try if i am home during the next cloud. I may also disconnect the blue channel dimming wire and see what the result is.
The blue should stay the same. The white should slowly dim with flashes of varying length and intensity, like the videos above.
Got it on video if you want to see it but confirmed the white dim out on channel 0 and the blue are the ones flashing on channel 1. Is there something in the bottom part of the code which still has it flash on channel 1?cosmith71 wrote:The blue should stay the same. The white should slowly dim with flashes of varying length and intensity, like the videos above.
CheckCloud();
Also i just have a general question about this code (10,0,20,0,0,30,60,0) it is (Hour on, minute on,hour off, minute off,starting percentage,max percentage, minutes of ramp up, ?) not sure what this last one is?
Should i just change the whites to channel 1 and the blues to channel 0 and switch them in the void loop?
Doh!
Replace the void Strike() section with this.
void Strike()
// Flash on
int newdata=4095;
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 0.
newdata=ReefAngel.PWM.GetChannelValueRaw(0); // Use the channel number you're flashing here
So I had an issue when i tried this yesterday. At first it had dimmed out the blue instead of the white and was flashing in white, so white channel on and flashing white. Then it switched to having the blues on and still flashing white. Instead of tinkering with the code and trying to make sure all the channels are aligned, I am going to switch the channels and reenter code from the first post and see if this fixes the problem.
Just a question about the code.
I don't understand what this does, can you break it down to me like i am 5 years old
Thanks for you in advance
Well, #define's main use is to substitute one thing for another. Take this line for example:
When you go to compile and upload your code, the compiler goes through and replaces all the instances of ReturnPump with Port1. So this line:
is seen as this by the compiler:
This is a common way to give your ports easy to remember names. You don't have to remember what port your return pump is plugged in to, you just tell it ReturnPump and it knows what you're talking about.
THIS IS NOT HOW THIS IS USED HERE!
A second use, which is really just a clever programming trick, is to #define something just so it shows as #defined. They are used as a type of switch That's what these two lines do.
So notice that the second part of the #define is missing. We aren't doing a search and replace like in the first usage so we don't need that second part.
Down in the code is this:
This says "if forecloudcalculation has been defined, then insert 'if(cloudchange==255)' when you compile the code, if it hasn't been defined (else) then insert ' if (hour()==0 && minute()==0 && second()==1 && cloudchance==255) '".
These things exist outside of the compiled code. The compiler goes through and makes these substitutions and insertions before it compiles the code. It's a sneaky way to have the code write itself on the fly depending on what we want.
If we want the #else to be used instead we would just comment out the line like this so that forcedcloudcalculation isn't #defined. Remember that '//' causes everything after it (on the same line) to be ignored.
Hope this makes sense. It's been a long day.
#define ReturnPump Port1
ReefAngel.Relay.On(ReturnPump);
ReefAngel.Relay.On(Port1);
#else
#endif
//#define forcecloudcalculation // Uncomment this to force the cloud calculation to happen in the boot process.
Well that's a lot of info. I see some have two channels for there lights. I have lights I built with 3 different heat sinks and have each one on its own channel, as in my left heat sink whites and other colors on say channel 1 with the blues on channel 2. Middle heat sink whites and other colors on channel 3 blues channel 4. 3rd heat sink whites and other colors on channel5 blues on channel 6. Not sure if that's the exact set up but that's the general idea how there set up, so I can ramp up each set individually. I'm using analog dimming expansion with DDR drivers. Any special coding I need for clouds and lightning? I know the old dimmer could have a cloud come across the tank from left to right, is this possible with these codes or does it just dim all at the same time?
With this code, they all dim at the same time with clouds. As for the lightning, it's just a matter of adding code for the additional channels. I run left and right white channels on mine and they can flash individually or together.
I'm not familiar with DDR drivers. Do you have a link?
http://www.rapidled.com/mean-well-eln-6 ... le-driver/
Have you looked at the coding that went directly into the old dimmer?
I don't think I've seen it. Do you have a link to it?
I'm familiar with those drivers (ELN). They don't have a fast enough response time for the best lightning effects, but they still work.
