Cloud and Lightning Code for Dimming Expansion
PostPosted: Mon Nov 06, 2017 5:23 pm
cosmith71 wrote:Here it is. See this thread for general instructions.
Up in the globals section (somewhere before void setup()) add this line:
int DaylightPWMValue=0;        // For cloud code
In your loop, you need to find whatever function is controlling your white lights and set it to the DaylightPWMValue variable. For example, I use something like this:
DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,85,60,0);
 CheckCloud();
 ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
Which is a high res (12 bit) slope that starts at 1030, runs until 2200, starts at 0%, ends at 85%, and takes 60 minutes to ramp up and down. If this part confuses you, post your lighting control code and I can help you with it.
Essentially what this section does is set the baseline lighting for when there is no cloud going on. This is your everyday lighting routine.
At the very end of your code, after the final }, paste in all this stuff.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(12,00)
  // Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Mega2,Mega,Mega};
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=4095;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      else x=35;
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
As written, this flashes channel 1 on the standard 6 channel Dimming Expansion Module.
This version does not write times to the screen. That option does not work well with the new screen functions. It will write the times into the custom variables so you can see them on the portal.
What's new:
Lightning generator broken out into its own function strike() since it's somewhat longer and more complicated now for the dimming module.
Everything is in 12 bit hi-res now. This pretty much breaks "Slow" mode. I should probably just depreciate it.
As always, ask away with any questions or comments.
Is this going to work with the included dimming ports on the star controller? Or only with the dimming expansion. How would i go about changing this to work wit the included ports?
PostPosted: Tue Nov 07, 2017 4:49 am
It should mean only changing this line.
I haven't done much with the Star, but it should be possible. Give me a couple of days to look it up, unless someone else knows the function off the top of their head. :D
PostPosted: Tue Nov 07, 2017 6:12 am
This is the function that is controlling my lights if that is any help
ReefAngel.PWM.SetDaylight( PWMSlope( 15,0,22,0,5,30,90,0 ) );
And it appears as though the channels are labeled as such 1-4
DaylightChannel
ActinicChannel
Daylight2Channel
Actinic2Channel
lol not sure if this helps im completely new to this and still learning how all the code works.
PostPosted: Wed Nov 08, 2017 4:49 am
cosmith71 wrote:It should mean only changing this line.
This is wrong. :(
PostPosted: Wed Nov 08, 2017 4:53 am
Try this version.
viewtopic.php?f=12&t=4783
PostPosted: Wed Nov 08, 2017 8:34 am
Will try it out tonight. and let you know how it goes.
PostPosted: Mon Nov 13, 2017 6:17 pm
cosmith71 wrote:Try this version.
so unfortunately this version will not work with the star controller as well.
first set of errors I encountered had to do with the draw for the countdown on the screen and removing that section of code fixed that issue but still had plenty of errors when trying to compile.
Here is what it gave me:
firmware.ino: In function 'void loop()':
firmware.ino:113:65: error: too many arguments to function 'byte PWMSlope(byte, byte, byte, byte, byte, byte, byte, byte)'
ActinicPWMValue=PWMSlope(14,0,23,0,5,60,90,0,ActinicPWMValue);
In file included from D:\Arduino\libraries\Salinity/Salinity.h:25:0,
from firmware.ino:1:
D:\Arduino\libraries\Globals/Globals.h:1620:6: note: declared here
byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue);
firmware.ino:114:67: error: too many arguments to function 'byte PWMSlope(byte, byte, byte, byte, byte, byte, byte, byte)'
DaylightPWMValue=PWMSlope(15,0,22,0,5,30,90,0,DaylightPWMValue);
firmware.ino: In function 'void CheckCloud()':
firmware.ino:255:98: error: 'ReversePWMSlope' was not declared in this scope
firmware.ino:362:3: error: expected '}' at end of input
exit status 1
Previous
Return to How do I code ...
