Email Alert
rsalomez
Email Alert
Post by rsalomez »
Hello,
How do I code an alert when there is a Leak?
#include <WiFiAlert.h>
void emergencyLeak(char *message);
    InternalMemory.LCDID_write(255); //Old LCD
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.FeedingModePorts = Port3Bit;
    ReefAngel.WaterChangePorts = Port2Bit;
    // Ports turned off when Leak is detected
    ReefAngel.LeakShutoffPorts = Port4Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardHeater( Port1,245,761 );
    ReefAngel.StandardFan( Port2,771,255 );
    if (ReefAngel.IsLeakDetected())
      emergencyLeak("Leak");
    ReefAngel.Portal( "rsalomez", "xxxxxxx" );
void emergencyLeak(char *message){
  static WiFiAlert t;
  t.SetDelay(0);
  t.Send(message);
  DISPLAYLOG=true;
  LOGMESSAGE = message;
I also tried with the portal setting but I've got no email :
Portal() function requires security key: ON
Portal() security key: xxxxxx
Send email notifications --> ON
Email address(es): my email
Temperature 1 >= 28
Water Leak Flag = 1
Thanks for your help
Xender
Re: Email Alert
Post by Xender »
Hello,
No clue?
Thx
Salt Water Aquarium 60*60*60
Re: Email Alert
Should work...do regular portal alerts work?
Xender
Re: Email Alert
Post by Xender »
Yes temp alert are working but no leak alert
Re: Email Alert
Can you connect the RA and run Serial Monitor, trigger the alert and you should be able to capture the URL that gets called. Wondering if the key is an issue.
