Odd ATO pin output behavior on WiFi activity
joshlawless
Post by joshlawless »
I connected a Jebao WP-25 to my lowATO pins, and wrote some code to ramp the speed from ~38% to 100% 10 seconds out of every 2 hours.
    pinMode(lowATOPin,OUTPUT);
    if ( (hour() >= 8) && (hour() < 22) )
      if ( now()%7200<10 ) analogWrite(lowATOPin,255);
      else analogWrite(lowATOPin,96);
This seemed to work well enough, but I noticed one heck of an unexpected behavior. When I hit the refresh button in the Android app, or send any signal to the controller with the iPhone app (e.g., turning on or off a relay), it pulses the pump on that channel to full power, briefly (much briefer than the 10 seconds specified in the code).
Do I have some particularly nasty bug in this code somewhere that would explain that behavior? Is there a reason that the WiFi traffic would cause a voltage surge on the ATO pins?
#include <Moon.h>
#define Heater_300W           Port1
#define Heater_100W           Port2
#define Skimmer               Port3
#define Neck_Wipe             Port4
#define Air_Pump              Port5
#define Filter_Pump           Port6
#define Refuge_Light          Port7
#define Ozone_Gen             Port8
#define FlowWolf              Box1_Port1
#define Closed_Loop           Box1_Port2
#define Kalk_Stirrer          Box1_Port3
#define ATO_Pump              Box1_Port4
#define Return_Pump_L         Box1_Port5
#define Return_Pump_R         Box1_Port6
#define Heater_200W           Box1_Port7
#define Refugium_Pump         Box1_Port8
#define Neutral_White_Center  0
#define Warm_White_Center     1
#define Royal_Blue_Center     2
#define Cool_Blue_Center      3
#define Cyan_Center           4
#define Red_Center            5
#define Indigo_Center         6
#define Violet_Center         7
int MoonBlueLevel=0;
int SunBlueLevel=0;
    ReefAngel.Init();
    ReefAngel.AddStandardMenu();
    ReefAngel.Use2014Screen();
    ReefAngel.AddSalinityExpansion();
    ReefAngel.AddORPExpansion();
    ReefAngel.AddWaterLevelExpansion();
    ReefAngel.Add16ChPWM();
    ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port3Bit;                 // Skimmer
    ReefAngel.WaterChangePortsE[0] = Port4Bit | Port8Bit;  // ATO Pump and Refugium Circulation
    ReefAngel.OverheatShutoffPortsE[0] = Port7Bit;
    ReefAngel.DCPump.FeedingSpeed = 0;
    ReefAngel.DCPump.WaterChangeSpeed = 0;
    ReefAngel.Relay.On( Air_Pump );
    ReefAngel.Relay.On( Filter_Pump );
    ReefAngel.Relay.On( FlowWolf );
    ReefAngel.Relay.On( Closed_Loop );
    ReefAngel.Relay.On( Return_Pump_L );
    ReefAngel.Relay.On( Return_Pump_R );
    ReefAngel.Relay.On( Refugium_Pump );
    if ( ReefAngel.Params.Temp[T1_PROBE] < 775 ) ReefAngel.Relay.On( Heater_300W );
    if ( ReefAngel.Params.Temp[T1_PROBE] > 780 ) ReefAngel.Relay.Off( Heater_300W );
    if ( ReefAngel.Params.Temp[T2_PROBE] < 775 ) ReefAngel.Relay.On( Heater_100W );
    if ( ReefAngel.Params.Temp[T2_PROBE] > 780 ) ReefAngel.Relay.Off( Heater_100W );
    if ( ReefAngel.Params.Temp[T3_PROBE] < 775 ) ReefAngel.Relay.On( Heater_200W );
    if ( ReefAngel.Params.Temp[T3_PROBE] > 780 ) ReefAngel.Relay.Off( Heater_200W );
    ReefAngel.DCPump.Threshold = 80;
    ReefAngel.DCPump.SetMode( Sine, 100, 240 );
    moon_init(44,-116);   // approximate lat,lon for Boise, ID
    SunBlueLevel = PWMSmoothRampHighRes( 7, 30, 22, 00, 0, 80, 45, 0 );
    MoonBlueLevel = PWMSmoothRampHighestRes( Moon.riseH, Moon.riseM, Moon.setH, Moon.setM, 0, (int)(MoonPhase()/19), 45, 0);
    ReefAngel.PWM.Set16ChannelRaw( Neutral_White_Center, PWMSmoothRampHighRes( 7, 30, 22, 00, 0, 65, 45, 0 ) );
    ReefAngel.PWM.Set16ChannelRaw( Warm_White_Center,    PWMSmoothRampHighRes( 7, 25, 22, 05, 0, 65, 45, 0 ) ); // 05 minute longer
    ReefAngel.PWM.Set16ChannelRaw( Royal_Blue_Center,    max (SunBlueLevel, MoonBlueLevel) );
    ReefAngel.PWM.Set16ChannelRaw( Cool_Blue_Center,     PWMSmoothRampHighRes( 7, 30, 22, 00, 0, 40, 45, 0 ) );
    ReefAngel.PWM.Set16ChannelRaw( Cyan_Center,          PWMSmoothRampHighRes( 7, 30, 22, 00, 0, 20, 45, 0 ) );
    ReefAngel.PWM.Set16ChannelRaw( Red_Center,           PWMSmoothRampHighRes( 7, 15, 22, 15, 0, 40, 45, 0 ) ); // 15 minute longer
    ReefAngel.PWM.Set16ChannelRaw( Indigo_Center,        PWMSmoothRampHighRes( 7, 20, 22, 10, 0, 30, 45, 0 ) ); // 10 minute longer
    ReefAngel.PWM.Set16ChannelRaw( Violet_Center,        PWMSmoothRampHighRes( 7, 30, 22, 00, 0, 10, 45, 0 ) );
    ReefAngel.Relay.Set( Refuge_Light, !((hour() >= 10) && (hour() < 19)));
    ReefAngel.Relay.DelayedOn( Skimmer, 1 );
    if ( ReefAngel.WaterLevel.GetLevel() > 55 ) ReefAngel.Relay.Off( Skimmer );
    if ( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.Relay.Off( Skimmer );
    if ( !ReefAngel.HighATO.IsActive() ) ReefAngel.Relay.Override( Skimmer, 0 );
    ReefAngel.DosingPumpRepeat( Neck_Wipe, 0, 240, 30 );
    ReefAngel.DosingPumpRepeat( Kalk_Stirrer, 0, 240, 30 );
      ReefAngel.WaterLevelATO( ATO_Pump, 1200, 38, 40 ); // On at 38% and Off at 40% with 1200 second (20 minute) timeout.
    if ( (hour() >= 7) && (hour() < 8) )
      ReefAngel.WaterLevelATO( ATO_Pump, 3600, 38, 40 ); // On at 38% and Off at 40% with 3600 second (60 minute) timeout.
    if ( ReefAngel.Params.ORP>450 || ReefAngel.Params.ORP==0 ) ReefAngel.Relay.Off( Ozone_Gen );
    if ( ReefAngel.Params.ORP<400 && ReefAngel.Params.ORP>0 ) ReefAngel.Relay.On( Ozone_Gen );
    ReefAngel.Portal( "joshlawless" );
    ReefAngel.DDNS( "reef" );
int PWMSmoothRampHighestRes(byte startHour, byte startMinute, byte endHour, byte endMinute, int startPWMint, int endPWMint, byte slopeLength, int oldValue)
  LightsOverride=true;
  int current_hour = hour();
  long start = NumMins(startHour, startMinute)*60L;
  long end = NumMins(endHour, endMinute)*60L;
  long slopeLengthSecs = slopeLength*60L;
  if (start > end) // Start is greater than End so it is over midnight
    if (current_hour < endHour) start -= 1440L*60L; // past midnight
    if (current_hour >= startHour) end += 1440L*60L; // before midnight
  long current = NumMins(current_hour, minute())*60L + second();
  if (slopeLengthSecs > ((end-start)/2) ) slopeLengthSecs = (end-start)/2; // don't allow a slope length greater than half the total period
  if (current <= start || current >= end)
    return oldValue; // it's before the start or after the end, return the default
  { // do the slope calculation
    int pwmDelta = endPWMint - startPWMint;
    float smoothPhase;
    if ((current > (start + slopeLengthSecs)) && (current < (end - slopeLengthSecs)))
      return endPWMint; // if it's in the middle of the slope, return the high level
    else if ((current - start) < slopeLengthSecs)
    {  // it's in the beginning slope up
      smoothPhase = (((float)(current-start)/(float)slopeLengthSecs)*180.0) + 180.0;
      //smoothPhase = constrain(map(current, start, start+slopeLengthSecs, 180, 360), 180, 360);
    else if ((end - current) < slopeLengthSecs)
    { // it's in the end slope down
      smoothPhase = (((float)(current-start)/(float)slopeLengthSecs)*180.0);
      //smoothPhase = constrain(map(current, end-slopeLengthSecs, end, 0, 180), 0, 180);
    return startPWMint + (int)(pwmDelta*((1.0+(cos(radians(smoothPhase))))/2.0));
