I intend to add a dimming module and a 3rd powerhead later on down the road that I would like to throw into a 4/4/4 timing mix.
Here's my code:
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port2Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit;
ReefAngel.LightsOnPorts = Port2Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
// Use T3 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.Relay.On( Port3 ); // Sump powerhead
ReefAngel.Relay.On( Box1_Port1 ); // ATS air pump
ReefAngel.Relay.On( Box1_Port2 ); // Media Reactors
ReefAngel.Relay.On( Box1_Port8 ); // Display lights
ReefAngel.SingleATO( true,Port1,300,10 ); // ATO
ReefAngel.StandardLights( Port5,6,0,22,0 ); //Powerheads on @ 6 AM off @ 10PM
ReefAngel.StandardLights( Box1_Port4,0,0,9,0 ); //ATS LEDs on @ 12AM off at 9AM
ReefAngel.StandardHeater( Port6,780,805 ); //Heater
ReefAngel.Relay.DelayedOn( Port7,5 ); //Skimmer delayed on 5 minutes
ReefAngel.Relay.DelayedOn( Port8,3 ); //Return pump delayed on 3 minutes
ReefAngel.DosingPumpRepeat( Box1_Port3,0,60,170 ); //Aqualifter on every hour for 170 seconds
if ((now()%SECS_PER_DAY==31320)) //if it is 8:42 AM
{ReefAngel.FeedingModeStart();} //START FEEDING MODE
if ((now()%SECS_PER_DAY==67320)) //if it is 6:42 PM
ReefAngel.Portal( "Spotted" );
