Manually set portal wifi address
KRavEN
Post by KRavEN »
Is it possible to enter a url to manually set your portal wifi address without going through the wifi setup utility? I can reach my RA from the net with the RA app and via browser so port forwarding is all working properly.
Re: Manually set portal wifi address
You can telnet it on port 2000, but the idle time is pretty short.
KRavEN
Post by KRavEN »
I meant is there a way to manually set the Wifi address on the http://forum.reefangel.com/portal.php page. Mine has never been anything but blank.
That would mean your RA is not sending data to the portal...and I think it is in the profile settings for the initial configuration.
Yeah, if you go to the forum user profile, you can change, but if RA sends data to the portal, it will update that ip address to the most current one.
