Help with this PWM code
MDB1029
Re: Help with this PWM code
Post by MDB1029 »
    int DaylightPWMValue=0;        // For cloud code
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port2 );
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
    ReefAngel.SingleATOLow( Port5 );
        DaylightPWMValue=PWMSlopeHighRes(10,00,20,0,0,45,60,0);
     CheckCloud();
     ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
    ReefAngel.PWM.SetChannelRaw(0,PWMSlopeHighRes(9,00,22,00,0,40,90,0));  // Blues from 0900 to 2200 on a slope
    ReefAngel.StandardLights(Port7,18,0,10,0);  // Fuge light from 1800 to 1000
    if ( ReefAngel.PWM.GetChannelValueRaw(0) < 16 || ReefAngel.PWM.GetChannelValue(0)>100)
        ReefAngel.PWM.SetChannelRaw(0,16);    // Set a default moonlight value for after hours
    ReefAngel.Portal( "MDB1029" );
    ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 7
    #define Min_Clouds_per_Day 1
    #define Max_Clouds_per_Day 2
    #define Start_Cloud_After NumMins(12,00)
      // Add Random Lightning modes
      // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
      byte LightningModes[] = {Mega2,Mega,Mega};
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
      static byte lightningMode=0;
    #ifdef forcecloudcalculation
      if (cloudchance==255)
    #else
    #endif
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
          if (chooseLightning)
            chooseLightning=false;
          switch (lightningMode)
          case Calm:
            break;
          case Mega:
              // Send the trigger
              Strike();
            break;
          case Mega2:
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
              else lightningstatus=0;
              if (lightningstatus)
                DaylightPWMValue=4095;
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          if (cloudindex < numclouds)
          int x=0;
          else x=17;
          else x=35;
        ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
        if (lightningchance)
          int x=0;
          else x=57;
          ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
          else x=75;
    void Strike()
      int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
      for (int i=0; i<a; i++)
        // Flash on
        int newdata=4095;
        Wire.beginTransmission(0x40);      // Address of the dimming expansion module
        Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
        Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
        Wire.write(newdata>>8);            // This sends the MSB
        Wire.endTransmission();
        // Flash off.  Return to baseline.
        newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
        Wire.beginTransmission(0x40);    // Same as above
        wdt_reset();    // Reset watchdog timer to avoid re-boots
      cstart*=60;
      cend*=60;
I have no idea why that shouldn't work. I use it myself.
Try this. Remove these lines:
And replace them with this:
        if (hour()>=22 || hour()<9) ReefAngel.PWM.SetChannelRaw(0,16);
MDB1029
Post by MDB1029 »
cosmith71 wrote:I have no idea why that shouldn't work. I use it myself.
I switched the channel 0 to blues and the channel 1 to whites, re-copied the lightning code and the moonlight code you gave me and everything works perfect now.
I really appreciate all the help that you provide me
Awesome! You're welcome!
