ATO Only at night.
Ask in here.
cjrudy
ATO Only at night.
Post by cjrudy »
Try to code so my ATO only runs at night, I think I have this coded right.
Thoughts ?
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.StandardFan( Port5 );
    ReefAngel.SingleATOHigh( Port7 );
    if (hour() >=24 && hour() <=12)
    ReefAngel.Relay.On( Port7 );
    ReefAngel.Relay.Off( Port7 );
    ReefAngel.Portal( "cjrudy" );
Re: ATO Only at night.
No. there is no such thing is hour 25 so you can't do hour >24.
Hour goes from 0 to 23.
Also, the way you coded, it will simply turn the relay on all the time instead of ATO.
Try this:
if (hour()<=12)
cjrudy
Post by cjrudy »
ahh......thank you Roberto
