Wave maker function question
PostPosted: Wed Sep 30, 2015 8:41 am
Yes, it is in the loop section.
It will turn them both on on the first 12s of every 1200s.
PostPosted: Sat Jul 09, 2016 3:39 pm
I'm trying to get this functionality working as well and am not seeming to have any luck. What I think was supposed to happen in the code was that there would be a 5 second overlap every 90 seconds but that doesnt seem to be the case.
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port2,796,798 );
ReefAngel.StandardLights( Port4,18,0,12,0 );
ReefAngel.StandardLights( Port5,10,0,22,0 );
ReefAngel.StandardLights( Port6,10,0,22,0 );
ReefAngel.StandardATO( Port8,1200 );
if (now()%90<5)
ReefAngel.Wavemaker( Box1_Port1,90 );
ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Box1_Port1 ) );
ReefAngel.PWM.SetDaylight( PWMParabola(10,0,22,0,10,10,10) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,22,0,10,15,10) );
PostPosted: Sat Jul 09, 2016 8:56 pm
Remove this line:
if (now()%90<5)
PostPosted: Sun Jul 10, 2016 12:14 pm
rimai wrote:Remove this line:
if (now()%90<5)
OK, but is there a way to accomplish what I'm after?
PostPosted: Sun Jul 10, 2016 5:56 pm
Does it alternate though?
PostPosted: Mon Jul 11, 2016 11:49 am
Alternates perfectly, was just hoping to have some overlap with both running for a short period so it would create a little more turbulence occasionally. Guess I can implement that once I get a dimming expansion and hook the pumps up to that.
Previous
Return to How do I code ...
