Multiple scheduled outlet times
Spotted
Re: Multiple scheduled outlet times
Post by Spotted »
The other way with the else statement would look like this?
    if (now()%3600<900)
    { //Every 60 minutes
    ReefAngel.Relay.On(Box1_Port3);
    ReefAngel.Relay.Off(Box1_Port3);
I'm trying to learn how to properly use the if/else statement.
Like this:
    if (now()%3600<900)
you had an extra }
Spotted
Post by Spotted »
Yes
I see it, the line above the else line right?
So how about this? This looks a lot less complicated than the if else argument,.
Spotted wrote:So replace all of this
    if (now()%3600<900)
    ReefAngel.Relay.On(Box1_Port3); // Turn on Aqualifter for 15 minutes
with this?
ReefAngel.Relay.Set(Box1_Port3, now()%3600<900);
Yes and yes
Spotted
Post by Spotted »
I'm happy, my code is coming along.
Next project. Is there a way to get the power heads to go into Nutrient Transport mode after a feeding?
Can I modify this to work?
    if ((now()%SECS_PER_DAY==31320)) //if it is 8:42 AM
    {ReefAngel.FeedingModeStart();}
Just change the times to coincide with the automated feeding?
If you're good at reading code you should try and look through my INO. I know mine is a bit complex so I'll try and simplify the request here for you:
  int ntmDelay=300; // Time to wait before starting Nutrient Transport
  int ntmTime=7200; // Time to run Nutrient Transport
  static time_t t;
  if (now()-t > ntmDelay && now()-t < ntmTime+ntmDelay) {
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
    t=now(); // Run post feeding mode when this counter stops
Spotted
Post by Spotted »
Ok, I don't think I'm going to use the NT mode after feeding. I might schedule it at a certain time of the day instead.
I have another request. I have the 12V power thingy I want to use to run a couple of water solenoid valves. I understand that it shows up as another relay box. I understand that I need to write it in the code as follows to turn ports on and off.
ReefAngel.Relay.On(Box2_Port3);
Thing is I will only be using them right now as manual ports to refill my ATO reservoir and water change barrels. How do I make them accessible in the app?
They should show up once activated. If you don't already have a relay expansion, it should be Box1 rather than Box2.
Spotted
Post by Spotted »
I do have another relay. I have 2 regular relay boxes and then the 12 volt power expansion. How would I activate it? Just plug it in to the system and it adds another set of relays in the app?
Reference it in the code, then compile and upload and it should be recognized.
Spotted
Post by Spotted »
I'm sorry, I am not sure how to reference it in the code. I'm not a coder. I'm a home theater installer.. Sorry...
Spotted
Post by Spotted »
Actually I think I understand. I could just reference them as off in the code and then I will get the ability to control them in the app right? Something like this?
ReefAngel.Relay.Off(Box3_Port1);
ReefAngel.Relay.Off(Box3_Port2);
Is this right?
Spotted
Post by Spotted »
No, It should be
ReefAngel.Relay.Off(Box2_Port1);
ReefAngel.Relay.Off(Box2_Port2);
Box2 not Box3, yes?
I got a Main Relay (Box), Expansion Relay(Box1), and the Power Control Module(Box2)
Yes?
Yes
