Flow meter Testing
- jsclownfish
Re: Flow meter Testing
I tried this a bit today, but I couldn't get a response variable to the flow. I could see a 'fixed' reading on the screen for each one. I'm guessing I just had the lines incorrectly connected. Can you explain the wiring connections you are using with the IO?
-Jon
-Jon
- jsclownfish
So was the 5V line from an external source? I'm assuming the ground was wired to the unit directly.
-Jon
-Jon
Humm, I hacked my board and used a piece of wire to get 5V out.
I can post a photo later when I get home.
But, you can use external 5V just as well, with all the GNDs wired to the module, so they all have the same common ground.
- jsclownfish
I finally got around to playing with this some more last night and it worked well. I am testing it out now with the min/max function (http://forum.reefangel.com/viewtopic.ph ... 6&start=10) on a phosban reactor to see how it works and how variable the flow is through the day. I am using this pde on the I/O because I only need one sensor to test and I don't fully understand the PCINT functions yet. A really quick assessment of the flow (gal/hr) was reasonably close but still needs some tweaking.
-Jon
-Jon
#include <Wire.h>; //IC2 communication
volatile int NbTopsFan; //measuring the rising edges of the signal
int calc;
int hallsensor = 3; //The pin location of the sensor
void rpm () //This is the function that the interupt calls
NbTopsFan++; //This function measures the rising and falling edge of the hall effect sensors signal
void setup() {
Wire.begin(9); // join i2c bus with address #9
Wire.onRequest(requestEvent); // register event
//flow setup
pinMode(hallsensor, INPUT); //initializes digital pin 2 as an input
attachInterrupt(1, rpm, RISING); //and the interrupt is attached
void loop() {
//flow calculations
NbTopsFan = 0; //Set NbTops to 0 ready for calculations
sei(); //Enables interrupts
delay (1000); //Wait 1 second
cli(); //Disable interrupts
calc = (NbTopsFan * 60 / 7.5)*.264; //(Pulse frequency x 60) / 7.5Q, = flow rate in L/hour
void requestEvent()
Wire.send(calc); //send info on flow
- jsclownfish
I've been trying to get my IO expansion loaded up with both inputs and outputs, but I am struggling trying to modify the flow meter code originally posted. I'd like to add a couple ATOs as level warning sensors (one in the overflow and one in the water reservoir). These would be additional INPUTs from the IO (along with the 3 flow sensors). I also would like to move the buzzer alarm as an OUTPUT to the IO. I am trying to just send a number to trigger the alarm or ato state. Maybe there is a better way to do this, but I'm still pretty green at this coding and I really don't understand the interrupts, so I'm kind of tripping over myself.
Here is the test master code I am trying to test the IO...
and the test IO slave code...
right now I get a screen like this:
0
0
0
255
255
0
and no response. Since it isn't hooked up to any sensors the buzzer is just triggered by a the ato singal in the master (kind of a circular aresponse, but it's jsut a test) I've had success sending info before, but I'm getting confused with this one. Anyhelp would be greatly appreciated.
-Jon
byte IOIn[10];
int Flow0;
int Flow1;
int Flow2;
byte buzz = 0;
byte Overflow;
byte Reservoir;
ReefAngel.Init();
ReefAngel.Refresh();
GetFlow();
ReefAngel.LCD.DrawSingleMonitor(Flow0, COLOR_BLACK, 5, 10, 1);
ReefAngel.LCD.DrawSingleMonitor(Flow1, COLOR_BLACK, 5, 20, 1);
ReefAngel.LCD.DrawSingleMonitor(Flow2, COLOR_BLACK, 5, 30, 1);
ReefAngel.LCD.DrawSingleMonitor(Overflow, COLOR_BLACK, 5, 40, 1);
ReefAngel.LCD.DrawSingleMonitor(Reservoir, COLOR_BLACK, 5, 50, 1);
ReefAngel.LCD.DrawSingleMonitor(buzz, COLOR_BLACK, 5, 60, 1);
if (Overflow == 1)
buzz == 1;
buzz == 0;
//send data parameter package to the auxillary monitor
Wire.beginTransmission(9); // transmit to device #9
Wire.write('$'); // send the $$$
Wire.write('$');
Wire.write('$');
Wire.write(buzz);
Wire.endTransmission(); // stop transmitting
void GetFlow()
Wire.requestFrom(9,9);
if(Wire.available())
for (int a=0;a<10;a++)
IOIn[a]=Wire.read();
Flow0=(IOIn[1]<<8)+IOIn[2];
Flow1=(IOIn[3]<<8)+IOIn[4];
Flow2=(IOIn[5]<<8)+IOIn[6];
Overflow=IOIn[7];
Reservoir=IOIn[8];
#include <avr/wdt.h>
//wire.write variable number
byte param[2];
byte IOports3;
byte IOports5;
byte IOports6;
byte IOports9;
byte IOports10;
byte IOports11;
byte Overflow=0;
byte Reservoir=0;
byte Buzzer=0;
byte IOOut[7];
volatile int Flow0 = 0;
volatile int Flow1 = 0;
volatile int Flow2 = 0;
unsigned long lastmillis=millis();
void FlowMeter1()
Flow1++;
SIGNAL(PCINT0_vect) {
Flow0++;
SIGNAL(PCINT2_vect) {
Flow2++;
void paramsend(int a)
param[0]=(byte)(a>>8);
param[1]=(byte)(a);
Wire.write(param,2);
// Serial.begin(57600);
Wire.begin(9);
pinMode(IOports3,INPUT);
digitalWrite(IOports3,HIGH); //pull up resistor
pinMode(IOports5,INPUT);
digitalWrite(IOports5,HIGH); //pull up resistor
pinMode(IOports6,INPUT);
digitalWrite(IOports6,LOW); //pull up resistor
pinMode(IOports9,INPUT);
digitalWrite(IOports9,LOW); //pull up resistor
pinMode(IOports10,OUTPUT);
digitalWrite(IOports10,LOW); //pull up resistor
pinMode(IOports11,INPUT);
digitalWrite(IOports11,HIGH); //pull up resistor
PCMSK0 |= (1<<PCINT3); // Pin 11
PCICR |= (1<<PCIE0); // Interrupt 0
PCMSK2 |= (1<<PCINT21); // Pin 5
PCICR |= (1<<PCIE2); // Interrupt 2
MCUCR = (1<<ISC01) | (1<<ISC01); //Rising edge
attachInterrupt(1, FlowMeter1, RISING); // Interrupt 1
wdt_enable(WDTO_1S);
wdt_reset();
if (millis()-lastmillis>1000)
IOOut[1]=Flow0>>8;
IOOut[2]=Flow0;
IOOut[3]=Flow1>>8;
IOOut[4]=Flow1;
IOOut[5]=Flow2>>8;
IOOut[6]=Flow2;
Flow0=0;
Flow1=0;
Flow2=0;
Overflow=0;
Reservoir=0;
//overflow sensor
if (digitalRead(IOports6) == HIGH)
Overflow == 1;
Overflow == 0;
//reservoir sensor
if (digitalRead(IOports9) == HIGH)
Reservoir == 1;
Reservoir == 0;
//overtemp alarm
if (Buzzer = 1)
digitalWrite(IOports10,HIGH);
void requestEvent() {
paramsend(Flow0);
paramsend(Flow1);
paramsend(Flow2);
Wire.write(Overflow);
Wire.write(Reservoir);
void receiveEvent(int howMany)
if (howMany==4) // Our custom protocol is 4 bytes
byte cmd1,cmd2,cmd3,cmd4;
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
Buzzer=cmd4;
for (int a=0;a<howMany;a++)
Wire.read(); // if the number of bytes is not 4, discard everything
0
0
0
255
255
0
-Jon
Try this:
byte Overflow=0;
byte Reservoir=0;
byte Buzzer=0;
byte IOOut[9];
void FlowMeter1()
Flow1++;
Flow0++;
Flow2++;
Wire.begin(9);
pinMode(3,INPUT);
digitalWrite(3,HIGH); //pull up resistor
pinMode(5,INPUT);
digitalWrite(5,HIGH); //pull up resistor
pinMode(6,INPUT);
digitalWrite(6,HIGH); //pull up resistor
pinMode(9,INPUT);
digitalWrite(9,HIGH); //pull up resistor
pinMode(10,OUTPUT);
digitalWrite(10,LOW); //pull up resistor
pinMode(11,INPUT);
digitalWrite(11,HIGH); //pull up resistor
wdt_reset();
IOOut[0]=0;
IOOut[1]=Flow0>>8;
IOOut[2]=Flow0;
IOOut[3]=Flow1>>8;
IOOut[4]=Flow1;
IOOut[5]=Flow2>>8;
IOOut[6]=Flow2;
Flow0=0;
Flow1=0;
Flow2=0;
//overflow sensor
Overflow = digitalRead(6);
//reservoir sensor
Reservoir = digitalRead(9);
IOOut[7]=Overflow;
IOOut[8]=Reservoir;
//overtemp alarm
digitalWrite(10,Buzzer);
Wire.write(IOOut,sizeof(IOOut));
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
Buzzer=cmd4;
- jsclownfish
FYI, I noticed you can buy these at http://www.adafruit.com/products/828 now. I really like being able to see the 'plumbing' is working properly on my various lines. The more powerful lines now just have a PVC T connector in place to let most of the water bypass, but keep the meter moving off the feed. It's not really accurate for flow rates, but I can definitely see the pumps are working and if they start to slow down.
-Jon
-Jon
- jsclownfish
I would like to add a few more of the newer large flow meters that are out there, but I don't really understand the pin change interrupts and registers. Can the I/O handle more flow meters (5 total) or do I need another I/O module? How would I modify the code above?
Jon
Jon
Very interesting. I'd love to have one for the inlet of my calcium reactor.
- jsclownfish
Hi all,
A quick FYI...
I use small G1/2 flow sensors on an IO expansion module on my system to monitor flow from the various pumps. They work well to provide some data that water is flowing properly and there are no clogs are major flow issues. The downside of these is they are kind of small and in my experience they can stop working after about a year. On the positive, they are relatively cheap and I just use a T on the return lines to let any extra flow bypass the sensor. It also provides some back-up in case the flow meter got clogged (although that has never happened).
Anyway, I went to order a couple new flow sensors http://www.seeedstudio.com and was happy to see there are much larger versions available now. They can handle larger flow rates (up to 120L/min for a G1-1/4) and may be useful for larger flow lines. Here is a pic of some of the new ones I just got in...
A quick FYI...
- photo (2).JPG (41.66 KiB) Viewed 8481 times
Has any one tried something like this?
puratekdotcom/products/insight-monitor-controller/accessories/flow-sensors
They seem more reliable and less likely to stop flow upon failure.
Granted, they don't tell you flow rate, but tell you if there is flow. This is more suited for a return pump or higher flow pump.
They work with a little "paddle" sticking in the flow stream and that paddle is connected to a micro switch.
Somewhere on his site I saw a non-intrusive level sensor, which seemed cool as well.
- jsclownfish
Those look interesting. I haven't had any problems with flow stopping upon failure. When they wear out or get stuck the water moves around the little paddlewheel pretty freely.
-Jon
-Jon
- ewaldsreef
- Contact:
If the readings are acurate this could be a very helpful add on. If you had a sensor on your return pump you could monitor for efficiency. I do aquarium maintenance for a living. There are so many return pumps out there working at lower capacity because of debris on the impeller. Also so many tanks with UVs and chillers that are running way to much or to little flow to be effective.
The big question is reliability and accuracy.
- jsclownfish
I use a number of them to monitor flow, but I don't really count on accuracy to determine efficiency of the pumps, just that the flow is working and in the general range I expect.
Jon
Jon
- ewaldsreef
- Contact:
Jon
I was going to add one to my RO to monitor water usage to let me know when to replace filters. Do you think it would be accurate enough to accomplish this?
