Dual ATO based on time
Re: Dual ATO based on time
Look at the ports in each statement. You should be turning off the opposite port when one is being used for ATO. Right now you declare port 7 as the ato then you turn it off for example.
slm222
Post by slm222 »
Ok, yes I will try that. Thank you for your quick response.
The reason I did it was on DMNYnkees code he said he needed to put that in order for the pumps to stay off during the switch over.
Right but he's turning off Port 8 when he's ATO is on Port 5 and vice-versa. You were turning off Port 7 when your ATO was on Port 7... which is a conflict.
slm222
Post by slm222 »
oh I see now.
I just tried the code below and after 8 am the kalk pump still turned on instead of the regular pump
if ((hour()>=20 || hour()<=8) && (ReefAngel.Params.PH < 825))
    ReefAngel.SingleATO( true,Port7,300,0 );   //  Sump switch. Kalk schedule 8pm - 8am if pH < 8.3  If ATO/Kalk runs for 210 seconds, then shut off and send alert.
    ReefAngel.SingleATO( true,Port8,480,0 );   //  Sump switch.  If ATO/RoDi runs for 210 seconds, then shut off and send alert.
I tried adding this to the regular pumps code, but didn't work
else if (hour()>=8 || hour()<=20)
slm222
Post by slm222 »
I will try this, with the relay off ports corrected, when I go home for lunch.
    ReefAngel.Relay.Off(Port8);
    ReefAngel.Relay.Off(Port7);
If you want it to go to 8am you need to change <=8 to <8 otherwise it will go to 8:59am.
Also the Off's are needed for sure to make sure the port you want off stays off.
slm222
Post by slm222 »
ok. that makes sense. I will try it tonight at switch over. thank you.
slm222
Post by slm222 »
thank you very much for correcting my oversight! I am curious as to whether or not it should have true or false in the statement and not sure what that represents?
true should mean LowATO versus HighATO.
Reefology
Post by Reefology »
anyone see any issues with this?
//kalk reactor
if ((hour()>=23 || hour()<=14) && (ReefAngel.Params.PH < 830))
 ReefAngel.DosingPumpRepeat2( Port7 );   //  Kalk schedule 11pm - 2pm if pH < 8.3  kalk dosed as per portal settings
 ReefAngel.Relay.Off( Port7);
