How do I set the date/time on a custom menu?
gaberosenfield
Post by gaberosenfield »
I have a custom menu set up, but I can't figure out how to give myself the option to set the date/time from the custom menu. Here's what I have so far:
//Custom Menu Code
prog_char menu0_label[] PROGMEM = "Manual Feed";
prog_char menu1_label[] PROGMEM = "Start AWC";
prog_char menu2_label[] PROGMEM = "Clear Alerts & Vars";
prog_char menu3_label[] PROGMEM = "pH Calibration";
prog_char menu4_label[] PROGMEM = "Toggle All Pumps";
prog_char menu5_label[] PROGMEM = "Set Date and Time";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label
void MenuEntry1()
  feedsToday += 1;
  wp25On = false;
  feedingPauseTimer = now();
  feeding = true;
void MenuEntry2()
  if (!ReefAngel.IO.GetChannel(0))
    AWCToday = false;
    AWC = true;
void MenuEntry3()
  //Clear portal variables.
  ReefAngel.CustomVar[Var_AWCCountTotal] = 0;
  ReefAngel.CustomVar[Var_AWCCountToday] = 0;
  ReefAngel.CustomVar[Var_AWCDrainFail] = 0;
  ReefAngel.CustomVar[Var_AWCFillFail] = 0;
  ReefAngel.CustomVar[Var_AWCOverflowFail] = 0;
  ReefAngel.CustomVar[Var_AWCATOFail] = 0;
  //Clear AWC control variables.
  AWC = false;
  AWCToday = false;
  AWCFail = false;
  AWCCheck = 0;
  AWCDrainCheck = 0;
  //Clear ATO timeout.
  ReefAngel.ATOClear();
void MenuEntry4()
  ReefAngel.StartSetupCalibrateChoicePH();
void MenuEntry5()
void MenuEntry6()
  ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.SetupDateTime();
What should I do to get this to work?
Gabe
Re: How do I set the date/time on a custom menu?
your menu entry should only be this.
void MenuEntry6(){
you had an extra line in it.
gaberosenfield
Sorry for such a late reply!
I see my original error now. Probably a stupid copy paste error.
I tried your solution. I got an error saying I needed a semicolon after the "ReefAngel.DisplayedMenu = ALT_SCREEN_MODE" line. I added one. Then I uploaded the modified code and it did exactly what my code did originally. When I select the option from the RA, the screen just flashes to a blank screen for a split second and then it takes me back to the menu. I cannot change the time on my RA.
I would just use the RA app to set the time, but I cannot get it to connect. I need to fiddle with my router settings again, but that's another story...
Any other advice on how to get the setup date & time menu option to work?
gaberosenfield
Ok, I got my RA app working again. I used it to set the proper time. I still can't do it from the custom menu on the RA though...
hmmmm... i believe it should work. unless something changed in newer versions of the libraries or with the new screen.
Try removing this line:
