Multiple Light On Times
tmoore103
Post by tmoore103 »
Hello fellow reefers,
I'm a newbie to both coding and the ReefAngel system so I'm hoping you pros can help me out. :D I got my system a few weeks ago for my nano reef and I absolutely love it! This will probably be pretty easy for you guys.
I'm trying to turn a port on at multiple scheduled times ( from 10 am to 11am and again from 11 pm to 7 am ) but I can't seem to figure it out. I've searched all over the forum but I can't seem to find what I'm looking for. So far I've tried these lines but couldn't get them to work.
First:
ReefAngel.StandardLights( Port3,10,0,11,0 );
if (bitRead(ReefAngel.Relay.RelayData,Port3)==0)  ReefAngel.StandardLights( Port3,22,0,7,0 );
Then I thought maybe I was just complicating things so I tried this:
Then this:
if (hour()>=10 && hour()<11)
  ReefAngel.Relay.On ( Port3 );
I was getting an upload error when I tried the last so I tried adjusting the code a little. It eventually let me upload the last one but it doesn't look like it's working. Any help would be greatly appreciated.
-Tori
Re: Multiple Light On Times
Try this:
if ((hour()>=10 && hour()<11) || (hour()>=23 || hour()<7))
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.Off(Port3);
Or, more succinct and not as easy to understand (does the same thing)
if (hour()==10 || hour()==23 || hour()<7)
Lots of ways to do it. :mrgreen:
tmoore103
Post by tmoore103 »
Thanks Colin! Really appreciate the help man. Thanks for showing me more than one way to do it.
No problem. :)
bkc6868
Post by bkc6868 »
If the port is already programmed for a certain time to come on by the wizard and we use this code, does the wizard code have to be deleted for that port? I have that port set to come on from 2 till 10 , but want to use this for multiples times instead. I used the code and it come on at the time I set but didn't go off
Whatever comes last in the code takes priority. Post your code and what you want to happen.
bkc6868
Post by bkc6868 »
I used this code but changed the times in it to 10 a.m. on and off 2 p.m. I the wizard the port is supposed to run till 2pm till 10pm. After loading this cusom code with my time changes it cam on at 10a.m. but didnt shut off at 2p.m like the custom code was supposed to do them back on at 6pm till 10 pm
bkc6868
Post by bkc6868 »
double post.. sorry
The wizard code and the new code will conflict. We need to see the whole code you are using.
Most likely we will want to take the wizard code and have the lights come on from 10am till 10pm then add a statement to turn them off between 2pm and 6pm
bkc6868
Post by bkc6868 »
Here is my wizard code. I took the custom code from above out
[/co#include <ReefAngel_Features.h>
    ReefAngel.FeedingModePorts = Port2Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 810 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardFan( Port1,785,790 );
    ReefAngel.StandardLights( Port3,14,0,22,0 );
    ReefAngel.StandardLights( Port5,6,0,18,0 );
    ReefAngel.StandardLights( Port6,14,0,22,0 );
    ReefAngel.StandardHeater( Port7,780,785 );
    ReefAngel.SingleATO( false,Port8,180,0 );
    ReefAngel.Portal( "bkc6868" );
    ReefAngel.DDNS( "www.reefangel.com" ); // Your DDNS is bkc6868-www.reefangel.com.myreefangel.com
de]
Specifically, which ports do you want to run at what times? I'm still not sure what you're trying to do.
bkc6868
Post by bkc6868 »
Port 3 from 10am to 2 pm and again at 6 pm to 10 pm
Change this line:
to this:
ReefAngel.StandardLights( Port3,10,0,22,0 );
if (hour() >=14 && hour() <18) ReefAngel.Relay.Off(Port3);
bkc6868
Post by bkc6868 »
Thank you!
