So i finally got around to building my led strip and it's working great. I have it on a timer to turn on at 10am and off at 11pm. I've recently noticed I'm loosing the color I obtained by switching to t5. So I need to change led schedule. I want leds to come on from 10am to 12pm then back on again at 8pm to 11pm.
Is this doable and if so how.
Led strip program
Re: Led strip program
Add a line to turn off the relay between those hours
if (hour()>=12 && hour()<23) ReefAngel.Relay.Off(Port1);
Just add under the coinciding port?
Put in custom section so you can reuse easier later but yeah as long as its after the line that turns the port on. Make sure to replace Port1 with what you need to turn off
so input code now head unit keeps reseting. wont stay loaded. I removed line and still. Only after i removed custome lables did it act right any ideas?
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
ReefAngel.CustomLabels[0]="RETURN";
ReefAngel.CustomLabels[1]="HEATER";
ReefAngel.CustomLabels[2]="SKIMMER";
ReefAngel.CustomLabels[3]="POWER HEADS";
ReefAngel.CustomLabels[4]="ACTINICS";
ReefAngel.CustomLabels[5]="DAY LIGHTS";
ReefAngel.CustomLabels[6]="FAN";
ReefAngel.CustomLabels[7]="ATO";
ReefAngel.CustomLabels[8]="UV";
ReefAngel.CustomLabels[9]="CABINET LT";
ReefAngel.CustomLabels[10]="FUGE LIGHT";
ReefAngel.CustomLabels[11]= "LED STRIP";
ReefAngel.CustomLabels[12]="UNUSED";
ReefAngel.CustomLabels[13]="UNUSED";
ReefAngel.CustomLabels[14]="UNUSED";
ReefAngel.CustomLabels[15]="UNUSED";
ReefAngel.StandardHeater( Port2,780,790 );
ReefAngel.Relay.DelayedOn( Port3,5 );
ReefAngel.PHControl( Port4,818,822 );
ReefAngel.StandardLights( Port5,10,0,22,0 );
ReefAngel.StandardLights( Port6,12,0,20,0 );
ReefAngel.StandardFan( Port7,790,800 );
ReefAngel.StandardATO( Port8,60 );
ReefAngel.StandardLights( Box1_Port1,22,0,8,0 );
ReefAngel.StandardLights( Box1_Port3,21,0,10,0 );
ReefAngel.StandardLights( Box1_Port4,8,0,23,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,0,100,0) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,20,0,0,100,0) );
if (hour()>=12 && hour()<23) ReefAngel.Relay.Off( Box1_Port4 );
So back end of led code not working. The 7p to 11pm on off function doest work. The am part is ok tho...hmmm
that did it thanks!
also got custom lables to work.
